KK Finish Mower
   / KK Finish Mower #1
Bart
I just purchased a KK 5' Finish Mower from TSC...The tractor makes a terrible grinding sound when the PTO is "ENGAGED"
If the mower is not connected the PTO engages fine.The tractor is a Ford 1710 and I have adjusted the clutch.Now my question.......... With the PTO shaft connected to the mower gearbox should I be able to turn the PTO by hand and see movement in belts blades etc... My PTO will not budge!!!!
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
