KK chain guard
   / KK chain guard #1
ebeacham
Southport NC
TYM 723
I am looking for chain guards for my 6' King Kutter rotary cutter. Anyone know where to get them and how much?
   / KK chain guard #2
The only place I would know of is Tractor Supply Co. I've got a 4' kk and will be welding up my own probably alot cheaper.
   / KK chain guard #3
Ditto... Tractor supply has them.. though they ain't cheap..
Soundguy
   / KK chain guard
Went to Tractor supply but they did not have them. I am not sure the girl behind the counter knew what I was talking about. I guess I will make my own.
What size chain should I use?
   / KK chain guard #5
You can try kingcutter them selfs.The front one welds on I was told,and the back one bolts on,and they are not cheap. RICHARD GAUTHIER
   / KK chain guard #6
What are chain guards?
   / KK chain guard #7
Gutterman, I just picked a picture at random here for you to look at. The chain guard is the row of chains around the lower rear of the cutter shown to prevent the blades from throwing objects out from under the cutter. Front chain guards are also available and advisable.
   / KK chain guard #8
Gutterman, chain guards on rotary mowers (bush hogs) are a series of short chains hanging vertically down in front of the openings on the back and front of the mower. Rotary mowers can throw a rock or other hard object a considerable distance and be a danger if anyone is in the area. There are stories of rocks from a mower breaking windows, penetrating the siding of a barn or doing serious damage to an individual and the chain guards help prevent this. Even with chain guards it is best to make sure the area is clear of people when mowing. Hope that helps explain the term.
MarkV
   / KK chain guard #9
I have a BushHog SQ60. I called my dealer yesterday to inquire about purchasing chain guards. He told me my particular model (size) does not have chain guards, but does have a steel plate that can be mounted at the rear of the deck and a rubber guard that is mounted at the front of the deck. No chains because blades are too close to deck and would get under deck and be hit by blade. Cost of the two will be $70. Based on what I have been reading on this site, I would not bush hog without guards.
   / KK chain guard #10
Looks like the chain guards would be pretty simple to make. I have a Howse 6ft just like the one in Bird's link...I think I'll try making them vs purchasing from Howse.
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
1999 CHEVROLET C7500 UTILITY TRUCK (A53426)
1999 CHEVROLET...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
