Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,950
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I have a slide in range. Model is KSIB900ESS (slide in, convection oven / Induction top) stove. Suffering "F2-E0" error.
Frankly, it's been quirky since day one. There are several boards inside. I'm trying to ascertain which one I need to replace. Had a repair guy out here a year or so ago, he basically said "I'd replace this board for you.....if it doesn't fix it, we'd have to replace that board" (paraphrased)
So that suggests to me he doesn't really KNOW which is the problem. He wanted like $1,200 to swap out the single board and if I'm presuming it's the same part, I can buy the part for essentially $300. This means I could try it.... if it didn't work, swap another board (using his method) and still be cash ahead. By the way, this was the service guy from the very dealer from which I bought the unit.
I'm leaning towards the control board, part/item # W11100619 / Item # 4534437
Couple of my symptoms:
1. If I hit the oven light button, lights do not turn on. Open door, they work fine.
2. If I go into Error Codes mode, (cancel/cancel/start) the number 3 on pad doesn't advance anything, it's dead
3. If I just try to turn oven on, nothing happens with the keypad as I get the error that I need a service call
4. AFTER I hit (cancel/cancel/start) and fumble around....and then get OUT of that mode, my oven seems to work just fine
I'm thinking there is a 'main' control board inside this (the one referenced above) and there might be another control board for the actual control pad....
Wondering if anyone knows enough about this to push me in one direction or another. Frankly, I think I'm going to go ahead and just order a control board and start from there.
Appreciate any thoughts. (yes, I know to unplug unit prior to opening) This is within my ability to do.
