Kioti Tractor Owner - Middleton / Caldwell, Idaho
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #1
jak0413
Caldwell, IDaho
Kioti / DS4110HS
Hello out there (waiting for an echo),
I am Jeff, I recently purchased a 2112 Kioti DS4110HS tractor. Now I have two (1953 Super C Farmall is my other tractor). I live in Middleton / Caldwell area of Idaho.
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #2
Welcome neighbor!
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #3
Welcome to the forum Jeff from Branson Mo
Thank you, to my neighbor to the north!
Thank you James, I will let you know what I find.
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #6
Proof Kioti will still be around in a hundred years! :laughing:
(do they still use wheels or is it all anti-grav by then?)
Welcome to the forum!
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #7
Hi Jake. Welcome to the forum!
:welcome:
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #8
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
   / Kioti Tractor Owner - Middleton / Caldwell, Idaho #9
Welcome to Kioti of futures past.:laughing::)
Update: solenoid has three wire harness. Negative and 2 positives. One positive has 12 vdc continuous power, the other has one second of 12 vdc power when key is turned on. The one second burst has more amperage, "throw" coil and the continuous "hold" has less. (thanks K0ua). Even though both had current to solenoid, it wasn't enough amps to throw the coil. I installed a new engine stop relay switch and all is fine now.
Thank you all for welcome to sight and for assistance rendered! Jeff
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
