Kioti tractor info needed
   / Kioti tractor info needed #1
8226hamer
Indiana
Started with a B-20 Kubota, then B2910, now L2800
I am needing a 4X4 30HP HST tractor with a FEL and a good dependable PTO system. What does Kioti have to offer? I have now , a L2800 Kubota HST with 212 hours on it and probably around 20 PTO hours on it and the PTO has faild me twice. It has a weak PTO system for running a roto tiller and with my warranty about to expire and since Kubota will do nothing for me except let me trade it in for a different model, I am ready for a different brand. I know nothing about the Kioti brand, but from what I see they seem similar to Kubotas.
Do they make a dependable PTO system? What type do they use on most of their tractors? And if anybody can fill me in on how their Kioti has preformed it will help me in deciding on a new tractor and maybe not having to go through what I still am with Kubota.
   / Kioti tractor info needed #2
Kioti has the CK 30 and CK35 with HST for starters at 30 and 35 hp respectively and probably close matches to the L2800 in size. Kioti also has a new DK35se which is about 38hp HST model that is the next size up.
   / Kioti tractor info needed #3
The Kioti CK30 HST is a 30hp tractor with 22hp live PTO which is only 0.5 PTO hp less than a L2800 HST but 1 more engine hp. I beleive all HST tractors have a Live PTO
The Kioti has a greater 3pt lift capacity 1764lbs vs. 1435lbs (24" back), greater pump capacity 12.7 vs. 10.5 gpm and it's a heavier tractor 3055lbs vs. 2600lbs.
The only thing I have used the rear PTO for on my CK20 HST is for my 60" rear mounted snowblower and it has never let me down. These machines are rock solid performers.
   / Kioti tractor info needed #4
I rototilled with a Landpride 60 inch tiller all day this last friday behind my CK30 with a HST transmission. The PTO has been very dependable and solid for many many hours of brush hogging. The tilling job was very easy for the Kioti. You will notice many features with the CK are superior to the economy line L2800 you had.
   / Kioti tractor info needed #5
CK30 hst/bh/bs all I can tell you is that I did alot of shopping for my first tractor. I was thinking Kubota but for the price and service am happy with my Kioti. Plus if you do run into a problem with your tractor there isnt a better place to get answers than this site.
   / Kioti tractor info needed #6
I pulled a 66" tiller for 5 hours Sat on my CK35 and it did great. My tractor is only 3 weeks old w/ 14 hours, but I've been happy so far.
I was shopping for a Kubota until I ran across the Kioti and saw how much more I could get for my $$
   / Kioti tractor info needed #7
I have the independant PTO on my DK 35. I have hundeds of hours tilling, finish mowing, brush mowing, Etc. Never had a problem.
960 hours and the only thing I've replaced/repaired so far has been a tachometer cable ($8)
I found a Kioti dealer located about 40 miles from me. I think I will go and check their line of tractors out. I want a tractor with a independent PTO as this was what my first two Kubotas had and they never had any PTO problems at all. I need the tractor to be as small as it can be and still have enough HP to be able to pull a 5' lawn gill pulverizer and run my 1550 Land Pride tiller without the PTO system comming apart.
How is the warranty on Kioti tractors? This is why I must get a different tractor now. The PTO system has failed twice on my L2800. The tractor has 212 hours on it with around 20 hours of PTO use, and it being 23 months old and the basic warranty lasting 24 months, and from my experience so far this system is going to fail again, the next time it looks like I will have to pay the bill. The tractor has to be split for this repair and it will not be cheap, so the warranty is a selling point of a tractor for me and also if the maker will stand behind it.
   / Kioti tractor info needed #9
2 years bumper to bumper and 4 years engine and drivetrain.
Kioti Warranty
One of the best warranties on the market.
Also, the Kioti DK35 has a 28.3hp hydraulic independnt PTO if that is what you want.
   / Kioti tractor info needed #10
The CK series Kioti is very close in size to your L2800, few inches difference here and there. It is available in 25,30, and 35 hp in the same chassis, with sychro shuttle or HST. Feature wise I think the CK is closer to the Grand L series than your 2800, things like telescoping 3pt links.
Bobcat 753 Skidloader (AS IS) (A50774)
Bobcat 753...
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
2022 Robex 55-9A Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2022 Robex 55-9A...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
