Kioti NX6010 vs John Deere 4720
   / Kioti NX6010 vs John Deere 4720 #1
kapper
Vienna, IL
Branson 7845C
I'm not sure if I have posted this already a few months ago, but in reading some of the recent Kioti Posts I though this might be a good thing to share. I made this video to demonstrate why I decided to keep my NX6010 and sell my John Deere 4720. I owned both of them at the same time for about a year. I've owned John Deere compacts for about the last 6 or 7 years prior to getting the Kioti. The Kioti has been just awesome thus far! (If you look further on my youtube page you will see the awesome projects that I have done with the Kioti in just the last 3 months).
Maybe this will help someone when comparing tractors, because as we all know it is really tough getting a TRUE side by side comparison, as they all skew things to fit their advertising goals (of selling 'their' brand).
I call things like I see them and have no allegiance with any particular product. I made my decision based on ACTUAL use to the tune of nearly 1,000 hours of John Deere (3720 hydro and 4720 hydro combined) and over 200 hours on the Kioti (Right now I'm almost at 350 on the Kioti).
Hope you enjoy it, and I apologize if I posted this earlier!
   / Kioti NX6010 vs John Deere 4720 #2
Nice Video, enjoyed it.
   / Kioti NX6010 vs John Deere 4720 #3
2nd that comment!!! Awesome video, nice job on the little things that can make a big difference!!! Congrats.
   / Kioti NX6010 vs John Deere 4720 #4
Hi Kapper,
Well I've watched just about every YouTube video you have and read most of your TBN posts so now I think I'll just ask for your advice/opinion since you have a lot of real word experience with the two tractors I'm considering.
I have been struggling between the John Deere 3046R cab tractor 45.3 hp, 36.6 PTO hp (formerly the 3720) and the Kioti NX6010. I know there is quite a large difference in these two machines but I can't decide if the JD 3000 series chassis will be big enough or if I should just up to the next size frame. Either way I would go with the largest HP motor for a given chassis, that's why I have it narrowed down to these two models.
Considerations:
1. I live in upstate NY and I'll need to be able to trailer it 4 or 5 times a year to a couple of different location, one is an hour away and the other is 4 hours (In the Adirondack mountains) . I currently drive a fully loaded 2016 Doge Ram 1500 eco diesel that says it's rated to tow around 8,000 lbs, this is one of my main hesitations with the Kioti. I will technically be over weight but I'm sure it can tow it. I think you use an F150, what is it rated to tow?
2. If I go with the 3046R I could put a 72" belly mower on it and mow "most" of my yard in a nice air conditioned cab. I'm not sure how well mowing my yard with a rear finish mower on the Kioti would work??? (I don't think Kioti has a belly mower option) I currently mow with a 60" zero radius mower that is old and beat up but I would keep it to "touch up" around the house and some lower trees. One of my friends says that I won't mow with the JD because it's just to slow and hard to get in tight places but my allergies say otherwise, plus AC sounds nice!
3. I own 30 acres of land and would like to put in a lot of food plots so a tiller is a must have. I also have a lot of trails I would like to maintain (smooth out and mow). Lastly I'm considering buying a larger plot of land in the mountains, my fried just picked up 850 acres with a lake in the middle! I'm sure I'll be using the tractor on his property as well.
4. I'm concerned that if I go with the NX6010 then I'll need to buy all larger more expensive attachments.
5. Potential attachment list: Belly mower or rear finish mower, tiller, brush hog, pallet forks, york rake. Maybe a 4 in 1 bucket, I think this option makes more sense on the larger machine, I not sure if a 4 in 1 on the smaller bucket would open wide enough to make sense???? I like the skid steer quick attach system much better than the JD system, what have you observed while using the two systems? Is one better than the other? Is it worth the significant cost to up grade the JD?
6. Between these two machines the Kioti is much larger and several grand cheaper. The larger size is both a positive and a negative to me, better for earth engaging tasks and worse for transporting the machine.
7. In your opinion how do the kioti cabs stack up to the JD from the aspect of air quality? (think allergies)
I have a fair amount of experience with much larger equipment like dozers and excavators from back in my Army days and now I barrow my friends JD2520 rather often; it's way under powered, just flat out to small for what I would like to do. However I have no experience with the either of these chassis sizes.
All of your videos and posts have helped a lot; I have enjoyed watching and reading them, keep up the great work!!!!
Thanks in advance!
   / Kioti NX6010 vs John Deere 4720 #5
Not sure about the "tow rating" of your truck. Usually one wants to go by combined vehicle weights (GCVWR): good explanation for those not familiar: http://www.mytractorforum.com/3533410-post16.html
If you can get a lot more work done with a bigger tractor then it might be worth it to rent a bigger truck to tow with. And if it's going to be a year-in-year-out thing then maybe buy a bigger truck. Also, if you're going to pack along a bunch of implements then you're going to likely need a fairly big (long) trailer): EricTheOracle tows his NX6110, cab, with his F150 using a 20' trailer and says that he wishes he had a 24' trailer. Bigger trailer generally means more weight (and thus less actual cargo weight).
Hi Kapper,
Considerations:
Thanks in advance!
Whew..... OK, here we go... In order... raw HP. You mention that whatever tractor you get you'd get the max HP. This is obviously important to you, as it should be.. I'm not sure if you know but I also owned a Deere 3520, basically the open station of the 3720. For HP I'd pick the Kioti any day of the week. I'll get into that more, but basically you can do more with more HP, period.. There will be guys that argue this til they turn blue, but the fact of the matter is that once you start TAXING a tractor, it's real colors start to shine through. I'm not talking about your everyday mowing a small hayfield and a landscaping gravel project moving one small load of gravel. From what I'm hearing, you are serious about what you want to do with it!
Par 1. towing 4 to 5 times a year. Yes, the Deere is smaller, more narrow, lighter, so in theory, easier to tow. You mentioned your truck, with was one of the ones I considered when downsizing to a 1/2 ton, but the Ford was rated to tow 11,700. The Kioti is larger, and wider, and heavier, so again, in theory harder to tow.. However, with that said, think of the comparisons you are making here... Those very same criteria used for a 'tow friendly' tractor are ALL qualities that you really Don't want in a tractor. With a tractor, especially a compact, Size does matter, more weight IS better (for use) and a wider stance IS better (for use & safety). I nearly tipped over my 3520 several times, which was NOT cool!! And it wasn't doing anything real crazy, just a slight incline is all you need especially a rookie tractor user. I use a regular car hauler to haul the Kioti. The only difference I notice towing (beside gross weight) is that the Kioti only has about 1 to 2inches of clearance on each side by the wheel well of the car hauler. A little practice, follow the center of the bucket up with the center of the trailer and it's a piece of cake. I know this is a consideration, but I don't even like that it is one, when we are talking about tractors, and especially big acreage!! Maybe consider trading in the Dodge!! I bought my truck to fit my TRACTOR, not my tractor to fit my TRUCK! You are in the mountains.... ANY truck will be safe on the highways, but one tractor will be MUCH safer in hill country, the Kioti.
Mowing; I've never used a belly mower. I'd much prefer a 3 pt, or as you have a zero turn. Your friend is right that a belly mower on the Deere will be too slow for you. I use the BH26, which is a HD mower, yet with sharp blades it will mow a lawn nice and neat, once you get the nuances down.. And seriously, in the country, what kind of mowing are you talking about? Do you have an expensive home with a manicured lawn? Either way, you will keep the zero turn, which would seriously compliment a 3 pt mower, the bigger the better, and a 6' mower would be easy peasy on the Kioti, and probably OK on the Deere (light duty, not HD)... Remember that HP thing? Honestly, light duty mowing would be just fine on either, but on super thick nasty stuff you will wish you had the extra 15 hp of the Kioti.. The AC is Better in the Kioti... Just sayin'.... 100% for sure. I've had them both and know this to be true. I've sweated MANY, many times while running the AC in the Deere once it gets 90 plus... Never a problem in the Kioti..
Now, here we go.. a LOT of food plots... Tiller is a must... Either one will run a tiller. But either one won't run a 6 foot, Heavy duty tiller.. Go big (HD vs standard) or go home... A 6' tiller is better than 5, or 4, but any will get the job done, but obviously, will take longer. If you are concerned about your time mowing, your time plotting then should be just as important right? Hence, the 6' tiller would be best. Again, I think the Deere will max out but might run a 6' HD, but bog down a lot. And get into heavy, virgin sod, and you'll be wishing you had the extra 15 hp... (hmmm, where have we heard this before.. :).
Maintaining trails; A) Safety and stability.. You are in mountainous terrain. That extra 6 or 8 inches of wheelbase, lower center of gravity, and beefier frame/weight all speak for themselves when it comes to safety on hilly terrain. 'Smooth out and mow' trails; Basic, minor smoothing and mowing could be done with either. Mowing, again though, consider if you use a 5' vs 6' deck. Noticeable difference in getting more work done faster. If you are talking more than minor 'smoothing,' once again, HP, width, lower center and power reign supreme here... Filling your tires is a MUST no matter what tractor you get. But hands down, this one is Kioti.. Oh, and your friends 850 acres.... Seriously man, you will be sorely disappointed with the lower HP and narrow stance. Trust me, I owned that tractor! Then the 4720! Then the Kioti!
'Larger implements' ; The higher HP can run any SMALLER implement, but NOT the other way around. If you have implements, you could continue to use them. If you are acquiring new ones, the choice is simply up to you. the larger Kioti WILL NOT require you to buy bigger implements. Only if YOU want to. I have broken, bent, cracked all kinds of implements over the years (and tractors.. :). I have found that If I am buying a new implement that the extra few hundred dollars to go HD, or even medium duty, is well worth it. And if you are a smart shopper, man you can find good used stuff all over the country side. I have shopped every implement and have bought several from states far away, where it was still cheaper to have it shipped than to buy local! All of those implements you list could be used with either one though. A 4 in 1 bucket to ME is a MUST have when you live in wooded country, or in farm country. Not so much with smaller farms, or hobby stuff.. You could get a 4 in 1 for the Deere, but as you mention, it will have to be a little smaller, because it has to be lighter, so will have more limited use. I stuck with a Medium size, because the weight of a larger 4 in 1 is WAY too much, even for the Kioti.. I know this because the dealer ordered me the wrong one and it was sick heavy, and felt like I had a load of wet sand just riding around empty! So, I traded it back to him for the proper one for the tractor, most all 4 in 1 manufacturers have them in category slots for tractor size. But yes, you will be more limited with the Deere. The quick attach system is LIGHT years ahead of the Deere setup. Deere is just pricing themselves out of business here... You can get virtually ANY kind of implement out there these days for a skid steer quick attach. Oh, and resale for implements...? Skid steer has many, many more options. Now if you buy NEW loader attachments, most makers will make you John Deere mounts. But overall I think the skid steer quick attach is much, much better.
Air quality ?? Again, the Kioti. The Kioti has 2 large air filers on the cab, the Deere only has one. Simple math, and more attention to detail. I too have tons of allergies and take permanent meds for them..
I think you summed it up on your last paragraph about when you borrow the Deere 2520 being way underpowered for 'what I would like to do.' I am guessing that if you've seen my videos, there is a lot of that stuff that you would like to do...
In summary, my vote goes to the Kioti, man and it's not even close. Not even in the same stratosphere... And for the same price??? C'mon man... The ONLY thing that I do not have experience with is Re sale (On the Kioti).. Many guys have pointed this out to me (as opposed to trying to point out that they've done the same things with a similar Deere) that I may suffer greatly upon resale of the Kioti. This, I can't confirm. But I'll say this, I lost my ***** on selling my only 2 year old Deere 4720... Just sayin'... Maybe I'd lose even more on the Kioti, but I'm not too concerned right now.. I've got 425 hours on it so far, and it has been excellent. I did recently bend the grill guard, and the step up to the cab, but thankfully I didn't catch anything else! Now, I am going to be making a skid plate and maybe put a mesh grill on the grill guard. But the dents I've got in the steel screen on the hood show that I hit something nasty, and I'm pretty sure that it would have broke through the plastic hood mesh guard on the Deere...
That is my opinion, but based on facts that I have personally experienced with BOTH tractors. I'm also pretty sure that I have done a much wider variety of tasks with a tractor than the average user.. Oh, and BTW I don't get jack sh*& from anyone for any kind of advertising (Man, I sure wish I did as I've helped Kioti sell many tractors already!). This is JUST ME, and MY REAL WORLD PROPERTY MANAGING EXPERIENCE! GOOD LUCK...
I've got a 22' trailer, and often times I could use a 24!! But overall, the 22 gets it done, but not necessarily with Multiple implements.
   / Kioti NX6010 vs John Deere 4720 #8
Regarding mowers, you might consider a flail mower, if you don't have heavy brush. I LOVE blasting brush with my rotary mower (5-footer on my B7800), but my new NX5510 will wield a 7' side shift flail. Costly, for sure. [Probably - I can't speak from experience] Easier to trailer/move around than a rotary mower. Can get good cuts with them (very good cuts withe the right blades): I'm still amazed, however, at how well my rotary mower cuts "lawn" even with blade edges that are no sharper than my little finger! In my case I need navigation, so going with a "big" (nearly "huge" compared to my dinky B7800) tractor I cannot really afford to be swinging a big rotary behind it (I'd really, REALLY, love to go crushing through the brush with one, but this tractor isn't going to be brush slamming like my B7800).
Had I been able to afford a bigger tractor back when I bought (used) my B7800 I'd have done so. But, being new to tractors at the time it was probably best that I learned on something smaller- mistakes were lest costly than with something bigger: getting big machines unstuck isn't fun!
   / Kioti NX6010 vs John Deere 4720 #9
Wow, I mean wow, thanks guys!!!! I wasn't expecting such quick responses! or that detailed! thanks!
Dieselbound,
Renting a truck is an interesting idea and I haven't considered it before, I just took a look and for $90 I can rent an F250 for the day. Not a bad option to get by with until it's time to upgrade my truck.
I kind of think I would destroy a flail mower, I have a lot of thick brush to clear or were you considering it for mowing around my main yard? That might be a consideration, how well do they work going up and down hills? Do you have to constantly adjust the 3 point height?
Kapper,
Kioti should be sending you a kick back, they weren't even on the horizon for me until I started watching your videos, I was originally looking at JD, Mahindra & Kubota. I have dealers for all 3 of them within a 30min drive from my place. After you turned me on to Kioti it turns out that I have a Kioti dealer about 30min away. (not quite as convenient but still not to far)
OK, so now you have me leaning towards the Koiti..... Thanks for your input on the Kioti Air quality, that was a big concern for me and part of the reason I hate using my zero radius mower. I get absolutely covered when I use that thing, I may as well roll around in the grass. Your right about having a country yard, it doesn't have to be perfect, just not a hay lot.
Since I'm leaning toward the Kioti Now I need all the right attachments, I'm hoping to bundle it all together into one big monthly payment.... I completely agree with you about going with the HD attachments, I'd rather do it right the first time. My budget is between 50 and 60K, hopefully not more than 55K but ya never know. (I've been saving for a long time)
I'm thinking about a woods PRD8400 finish mower (84") to mow most of my yard and then touch up with my zero radius. My Kioti dealer is also a woods distributor so I'm sure I can roll some woods attachments into the deal.
For more serious cutting I'm thinking BB6000X Brushbull (60" cut) but I think the tractor is wider than the cut, is that an issue??? (how wide is the NX6010 with R4's, the website doesn't say) Would you go Bigger? Would a large cutter bog the tractor down it the thick nasty ****?
Woods SGT72 Rotary Tiller (72"), I think the tiller should be wider than the tractor but do you think the Kioti would have a problem spinning a 72" tiller in virgin ground? Would you recommend reverse or forward rotation?
What kind of 4 in 1 bucket do you have and would you recommend it or is there a better one available now days. I'm assuming you bought yours several years ago since your old 4720 videos had a 4 in 1. How wide is your bucket? You mentioned they accidently ordered the larger one but didn't say what size either of them were. Do you think it would be better to get a standard bucket and a Root Grapple? They are both lighter than a 4in1 so you would have more lifting capacity. Going that route would probably cost a little more but 4in1's are expensive.
What size pallet forks do you have and what size would you recommend? 42", 48", other?
Does Kioti offer a front snow blower for the NX6010?
I'll have to wait on a trailer for now and barrow my buddy's but it sounds like a 24' would be the way to go, thanks for the input!
JD deluxe grill guard is way better and I wish Kioti offered something like that, do you know of any after market guards, I don't think it will take me very long to smash something into it. I'll get carried way concentrating on the loader or something and completely over look the giant stick jamming into the grill....
Thanks again, all of your videos and posts have helped immensely!!!! This is a TON of money for me and I've been waiting for this day for about 15 years, so I can only hope that I make all the right choices.
   / Kioti NX6010 vs John Deere 4720 #10
Verify that that F250 can indeed tow (more) as needed. Usually you don't get increased towing capacity (over the 1/2 ton class) until you get to 1 ton and up (though this range also comes with more weight, which is a hit to GCVWR- note my comments below about HD stuff and weight).
Flail mowers are primarily grass mowers, but handle light brush well (depending on knives). Flails aren't as bullet-proof as rotarys, but for lots of grass and light brush they're better. Flails, most, utilize rollers, and it's the rollers that get set for cutting depth; the top link doesn't do much to affect the cut (from what I understand- I might be wrong, though if anything the affect won't be that significant). Given that the cutting action occurs closer to the rear of the tractor flails tend to ride the contours better and are more maneuverable (more so with an hydraulic side shift- I expect a fail to work well for me as I've got lots of trees and several ditches [slid fully to the right you can extend a fair distance- flail I'm looking at is around 2' shift past wheel edge]). All you could ever want to know about flails is in this thread:
http://www.tractorbynet.com/forums/attachments/118882-lets-talk-flail-mowers-new-post.html
Regarding the sizing of implements, the NX6010 is going to be able to easily run 7' mowers, 6' (or 7'?) box blade, 6' tiller (soil conditions vary, in which case, without knowing what you have, it's likely a safe general statement of size). Most tillers are, or can be, offset to cover one tire track. I just ordered 48"[EA] pallet forks. Pallet sizes can vary a bit, but tend to be about 44" for the most part, and it's good to be able to readily extend past the other side; also, with 48" you've got an additional 4" of reach with the tips if you're trying to coax stuff that's farther in on a trailer.
I was pretty much set on a 4in1 bucket -Kapper's vids are great!- but did a bit more research and decided to go with a grapple instead: went with an EA 66" single lid Wicked Root Grapple. My tractor won't be going off-property and I have plenty of room to store multiple implements. If you had limited room available to transport then the 4in1 would provide an advantage. For me, I've got lots of brush and debris, not necessarily a lot of stumps (though recently I'd cut several trees for a fence line and rented an excavator to remove the stumps- I bury the bigs one (burning for clearing isn't allowed where I live; I've got some stumps that I've dug that are likely over 10k lbs) several smaller stumps need to be moved but I'm pretty sure that my/the NX5510 with the EA grapple will handle them. Another thing that'll be a plus for me with a grapple (over a 4in1) is that I have a LOT of blackberries and when I'm running around mowing I kind of reach out and snag some (tooth bar on my B7800's loader bucket), ever widening my paths; wouldn't be able to do that with a smooth edge on a bucket, and, I don't think, the 4in1 wouldn't be very efficient with taking quick grabs at the blackberries. It's always about assessing your needs. Everyone's needs differ.
You don't need any tractor manufacturer's brand name implement. I strongly urge you to do some reading in the "Attachments" forum here. That's what I did: helped me decide on what grapple to get.
:laughing: Yeah, I hear you on the grill guard. I'd always wanted one on my B7800 (it's a Mad Max tractor, less the armor- it's used to slam through brush!), but I don't have a welder (no garage even!) I've smashed up some screens, but, ironically, have not put anything through the radiators/coolers! My NX won't be used in the same fashion as my B7800 but I still think that, for peace of mind (big tractor repairs mean BIG money), I'll look to fortify the "guard."
Careful about wanting to go all out HD. The heavier duty something is the heavier it is. If it's an implement for lifting things (such as a 4in1, a grapple, pallet forms etc) that extra weight means less total payload you can move. Doesn't make sense to get an implement that's rated for a lot more than what your tractor's lifting ability is. The NX loader is rated for roughly 2,700 lbs (to full height, at pins I believe). If you get a pallet fork that's rated for 4,000 lbs and it weighs 600 lbs that would mean you would be able to lift 2,100 lbs; if you got a pallet fork rated for 3,000 lbs and it's 450 lbs you're going to be able to lift 2,250 lbs. BOTH pallet forks will get the job done, and both are rated to handle more than your loader will lift. If you're using the forks to dig :)eek:) THEN HD would be the choice;) Stuff hanging off the rear of the tractor can be spec'd heavier duty because stuff you'd be hanging back there isn't likely needing to be lifting payloads: I've got what is likely the heaviest duty 5' box blade that's ever been manufactured on my B7800- It is indestructible (my tractor has suffered a consequence of this, though, with a bent lower link arm and now, just today, I broke the lift linkage on one of the arms!:mad: I'll be using it on my NX5510 until I can afford a larger box blade and I figure it'll hold up under the power of the bigger tractor).
BTW It's borrow when you're lent something.
1275 (A50490)
1275 (A50490)
Engel 20' Boat (A50121)
Engel 20' Boat...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
