KIOTI NX5010 OEL Warning Lamp - who would have guessed?
   / KIOTI NX5010 OEL Warning Lamp - who would have guessed? #1
rlaughton
Milton Ontario
Kioti NX5010 HST CAB
Temperature dropped to -10 deg C on Friday. Lots of work to do and planning for big snow storm Saturday. Tractor started fine, warmed up nicely, ready to get to work.
Ten minutes later, start losing power - OEL WARNING LAMP comes on and tractor stalls. It will restart and able to back it into a safe area - equestrian operation so lots of students and parents.
Manual says basic words like "Electrical and fuel delivery" problems. Call the dealer, might be diesel gel due to cold temperatures. Suggests adding fuel conditioner and if that does not work, remove and drain fuel filter, fill with fresh fuel (the filter) and try again.
Neither solution works. Head home and search the web - nothing here about the issue but I see some saying "DIESEL 911" is the best emergency solution - good, the storm is only 12 hours away. Off I go to get the product and a few others.
Dealer's service rep is 2 hours east of Toronto on another call and can stop by the farm on the way home. He is the only one with the scanner tool to check if there is an electrical issue with the fuel pump etc.
An hour later I hear from the dealer - they are great about helping in a crisis - that the service rep stopped at the farm. He got the same results, tractor starts, runs 45 seconds, OEL lamp lights, tractor shuts down. Starved for fuel he thinks - as I did I but no idea why?
TURNS OUT TO BE SOMETHING NOBODY EXPECTED - the air release on the fuel cap on the tank was plugged, probably condensation and froze. Without the fuel cap on the tank the tractor starts and runs perfectly. Clean out the fuel cap assembly and all is working well. Once it stalls and you leave it for a while, enough air gets into the fuel tank to allow it to start again, then the process repeats.
Regardless, I now have a batch of fuel additives for the next event and have added it to my 45 gallon bulk tank. It has a water/particulate filter as well, but it was real cold.
NO COST - the tractor is still under the 2 year warranty and it was a mechanical problem with the fuel cap.
   / KIOTI NX5010 OEL Warning Lamp - who would have guessed? #2
Around here, we don't get snow and it doesn't seem to freeze very often. But...our fuel caps get plugged by dirt, sand, and bugs. I operated a rented stump grinder the other day that I had to pop the fuel cap off to break the vacuum so it could get gas to the motor. I learned how to do that from dealing with the same issue on my JD mower.
Glad you found the problem, and a simple one to boot!
   / KIOTI NX5010 OEL Warning Lamp - who would have guessed? #3
I run a Stant fuel cap on my NX and have not had problems.
   / KIOTI NX5010 OEL Warning Lamp - who would have guessed? #4
Learned this from a small riding mower once.. it's something you don't forget after you've experienced it.
   / KIOTI NX5010 OEL Warning Lamp - who would have guessed? #5
Rlaughton, thanks for posting this. :thumbsup: It's sure not something I would have thought of, if it happened to me.
Your post says OEL lamp, but I don't recognize that on the NX series. By chance, was it the CEL (Check Engine Light)? Indicating a major electrical or fuel system problem.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51243)
KNOW BEFORE YOU...
(INOP) 2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
(INOP) 2007...
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
Kubota 48in Bucket (A50322)
Kubota 48in Bucket...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
