Kioti NX Oil drain plug size/pitch?
   / Kioti NX Oil drain plug size/pitch? #1
Overtaxed
New Member
Gaffney, SC
Kioti NX6010, JD 2720 w/46BH, Honda Pioneer 1000
Did my oil change last night and after quite a few in/out cycles, my two drain plugs are starting to get a little rough around the edges. I'd like to get two new plugs and replace them both on my next oil change, anyone know the size/pitch of the oil drain plug in a Kioti NX?
I think it's 12x1.25 but want to confirm that before I order up a few of them.
   / Kioti NX Oil drain plug size/pitch? #3
Not the same tractor…but my CK30HST uses the same oil pan plugs (2) as my 2013 Toyota Tacoma v6. Nice big heads on them. 👍
   / Kioti NX Oil drain plug size/pitch? #4
Suggest you invest in a metric thread pitch gauge and a cheap dial or digital caliper. You should be able to get both of these items for less than $20 total and if you do tractor or auto work routinely it's guaranteed you'll need them again
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
