Kioti NX 6010 Air filter(s) - One or two??
   / Kioti NX 6010 Air filter(s) - One or two?? #1
Overtaxed
New Member
Gaffney, SC
Kioti NX6010, JD 2720 w/46BH, Honda Pioneer 1000
Did my 200 hr service today and went to change the air filter. I have a Wix 46489 and 46490, a smaller and bigger filter that "nest" together and fit into the space correctly. The filter I pulled out did not have an "inner" filter, just the bigger one, it was empty in the middle. I put in the 2 filters and the tractor seems to run just fine, and, of course, more filtering is usually better, but, don't want to choke restrict the airflow too much; which is why I'm asking. Am I supposed to have 1 or 2 filters in there??
Thanks!
   / Kioti NX 6010 Air filter(s) - One or two?? #2
The inner filter is a safety filter Incase something gets past the primary one. Mine didn’t come with one when new so I purchased one that was over 500 hrs ago and no issues.
   / Kioti NX 6010 Air filter(s) - One or two?? #3
I run an inner and an outer filter on my DK 35.
   / Kioti NX 6010 Air filter(s) - One or two?? #4
Both my DKse tractors only came with one primary air filter as well. I noticed that the Donaldson intake setup was made to also accept the inner so I picked up those too. I would recommend it to anyone who has an air filter assembly that can accept the inner filter.
I'm sure I'm not the only one who just cleans up the outer air filter with some light air pressure from the inside out. Its possible to miss a tear in the filter pleating. That inner air filter is great protection for that. I change the outer and inner filters when I start seeing the inner air filter pick up a bit of dust.
In the past, people have mentioned 2 filters being more restrictive, but this is a non issue. That inner air filter should always be very clean, and a clean air filter flows very well.
   / Kioti NX 6010 Air filter(s) - One or two?? #5
My L4200 came with only one air filter. The operator's manual had two different maintenance descriptions, one for a single filter and another for a duel filter as you describe. I never added the second filter, just changed the single air filter more frequently than the scheduled replacement called out in the operator's manual. And of course, cleaned them between actual changes. 20 years without a problem.
I know you are talking about Kioti tractors, but it appears Kubota uses the same air filtering system on some of their tractors.
   / Kioti NX 6010 Air filter(s) - One or two?? #6
My Kubota was the same way also, had the dual air filter.
   / Kioti NX 6010 Air filter(s) - One or two?? #7
I would use both inner and outer, Its cheap insurance for a big $$ investment ....
Exactly what I did and how I looked at it. Just wanted to make sure I wasn't starving the engine for air by doing so, sounds like the definitive answer is "no". Just that the OEMs are cheap and don't put both filters in there, which seems pretty mind boggling to me!
   / Kioti NX 6010 Air filter(s) - One or two?? #9
What's even more mind boggling is that even some of the same model tractors strait from the manufacturer, some come with single filters while others come with both. For the few dollars more, they ALL should come with the inner filter along with the primary (outer filter). :confused3:
   / Kioti NX 6010 Air filter(s) - One or two?? #10
It comes down to $$$ that's all ,I change the inner every other time. I clean the outer if its dirty , And I never clean the inner I just change it..:)
Deere 317G (A50120)
Deere 317G (A50120)
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
Caterpillar 330FL (A50120)
Caterpillar 330FL...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
