Kioti Mechron 2200 ignition switch
   / Kioti Mechron 2200 ignition switch #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
my
Kioti Mechron ignition switch started acting up, when you turn key to start it will start but will not run when the key resets to the run position, i assume the switch is needing to be replaced, anyone had a similar issue and managed to fix it
update, switch from my local dealer is 150 plus 25 postage, so used the wd40 in the key hole then a blast of compressed air, did this half dozen times and switch works fine now, not that I am cheap but the postage was the kicker, a dealer should be able to get a switch with a regular shipment but they charge this 25 on all parts ordered
71054 (A49346)
71054 (A49346)
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
