Kioti LQ7320QA cutting edge plate bolt pattern
   / Kioti LQ7320QA cutting edge plate bolt pattern #1
desroses
Kioti RX7320
Next month I will receive a Kioti RX7320 tractor with LQ7320QA front loader. Anyone knows the distance bolt pattern of the cutting edge plate that goes on the edge of the bucket? I need the blade overall sizes as well as the hole distance center to center and from the edge of the plate to the center first and last hole. The Kioti RX7320 comes with a front loader but without a cutting edge plate. I would like to have one made of Hardox 500 and need the blade size, the holes distance pattern as well as the hole size and bolt type to used. I have to draw the blade on Inventor CAD for a CNC milling machine. I asked this question at least six times to my Kioti dealer without an answer yet. Thank you for your help.
   / Kioti LQ7320QA cutting edge plate bolt pattern #2
I don't, but if it were me, I'd wait until you get your specific loader and then take the measurements yourself. That will ensure that it will be exactly correct.
I say that because it's possible that someone else's measurements/holes my be just slightly different than yours, enough so that it might not fit.
just my thoughts...
   / Kioti LQ7320QA cutting edge plate bolt pattern #3
There are standard sizes and bolt patterns in the skid steer size and up machines. It's possible that you can find one with at least the right bolt pattern even if you have to trim a few inches off each end for the length. Should be a lot cheaper than buying the hardox and machining one.
I'm guessing that the factory edge is already drilled. Check SS and backhoe dealers if you can't find a business that specializes in wear egdes ;
Bucket teeth, edges and wear plates. There one of those "quiet" businesses that are in every fair sized cities, you just don't see them.
just my thoughts...
The RX7320 was scheduled for delivery end of March... it was delayed to end of April and now end of May... I think your suggestion is a wise one. I will wait and see. Thank you for your reply.
I was told $400.00 for a Hardox 500 double cutting edge blade size: 85'' x .5'' x 8'' including square bolts and locknuts. I wonder if I could also add Bucket teeth with the cutting edge plate?
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2007 BMW 750Li Sedan (A50324)
2007 BMW 750Li...
2 Axle Trailer (A50774)
2 Axle Trailer...
