Kioti LK3054 Repair Manual
   / Kioti LK3054 Repair Manual #1
crankman
Would like to know wheir I can buy a repair manual for my Kioti LK3054?? I have a oil leak that looks like it's coming from the valve cover or the top of the engine??, Where can I buy a valve cover gasket?? also the throttle control leaver does not hold the rpm's, I use a piece of wood to brace the throttle rod to keep the rpm's up while cutting grass and weed badgering. I would apreciate any help with these problems---crankman
   / Kioti LK3054 Repair Manual #2
follow the throttle level down to the pivot point. You will find an adjusting nut and a jamb nut. Loosen the jamb nut, tighten the adjusting nut to provide enough holding friction and tighten the jamb nut. It takes fairly thin wrenches and a little patience, but it works pretty well. Good luck. ps I bought manuals for my 2554 on line at a site that used to be Kioiti.com, but I think they changed it and let Kioti have the address. Maybe someone else can help with the web site name.
   / Kioti LK3054 Repair Manual #4
Bought mine from Jon Depratt at www.deprattequipment.com. Jon has been very helpful. I had to rebuild my entire engine. The parts were very inexpensive. I have all the mechanical work done. I have been so busy Jon that I have not had time to put all the electrics and body parts back on. Hope to accomplish this by grass cutting time.
   / Kioti LK3054 Repair Manual #5
One more thing crankman. Do you have a digital camera that you could take some pics of the electrical harnesses. This has been such a slow process I have kinda lost track of what went where. I will figure it out but a few close up pics from different angles sure would help. BTW mine is a 1995 model LK3054.
   / Kioti LK3054 Repair Manual #6
I was just thinking about you the other day. Was wondering if you got it all back up and going yet. Glad to hear all is well... !!
   / Kioti LK3054 Repair Manual #7
Hi Jon,
I just recieved that exhaust pipe and something else. I started in real estate in Sept. and I have been working my bunns off. If anyone is thinking of moving to middle TN drop me a line (Shameless plug /forums/images/graemlins/blush.gif) I hope the admin does not kill that. Anyways the manual is good for specs and some help but the pics are bad. Of course on the electrical they have a schematic which I am no good at. That is why it will either be trial and error (may be buying some electrical parts Jon) or find a similiar unit and get some decent pics.
Thanks to all, this is a great site. We are located in Thurman Iowa, about 35 miles south of Omaha Nebraska. We have a 6 acres of grapes and a winery. We use the Kioti 3054 for grass cutting, weed badgering, hole drilling, and post pounding,and all around dirth work. The Kioti tractor is great machine. I would if I could send digital pictures but I have Webtv and it not possible with Webtv.How big of a job to changes the valve cover gasket?? What is the price of the Kioti repair manual?? Thanks again---crankman
   / Kioti LK3054 Repair Manual #9
They now have out a new LK3054XS workshop manual which has replaced the LK3054 workshop... much better pics and more info as well...
   / Kioti LK3054 Repair Manual #10
</font><font color="blue" class="small">( How big of a job to changes the valve cover gasket?? )</font>
Easy job
</font><font color="blue" class="small">( What is the price of the Kioti repair manual?? )</font>
The service manual for my DK 35 was $65, the parts manual was $37.50. LK3054 manual prices are likely in the same area .
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
Pop up camper (A51694)
JCB 507-42 Telehandler (A51573)
JCB 507-42...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
