Kioti LK3054 ignition switch wiring
   / Kioti LK3054 ignition switch wiring #1
drosenkrantz
Nephi Utah
Kubota, Kioti
I have a Kioti LK3054 that the original ignition switch was replaced with a NAPA one. The wiring harness has four wires in it. Red=Battery, Red/white stripe=acc, Small black wire=starter and
a large Black wire that has been cut. The tractor starts,runs, and the lights work, but the alternator light stays on. I have not yet checked the alternator output yet but will. Any Ideas on
what the heavy black wire could go to. I can't find a wiring diagram for it. The four wire plug to the switch has been overheated, probably by the glow plugs . I plan on using a separate
wire for the glow plugs and resistor with a push button. Any help is much appreciated. Dave.
l
   / Kioti LK3054 ignition switch wiring #2
My owner's manual has a rather crude wiring diagram on the last page. It appears that there are 2 wires that come off the ignition switch go to the glow plugs...one thru the resistor/indicator, the other one bypasses the resistor (total of 5 wires to the switch, the glow-plug-thru-resistor one looks like it has it's own connector). The alternator output is directly connected to the battery thru a fusible link. Looks like it has a separate regulator.
The diagram doesn't show any of the idiot lights, so it's unclear how they're wired.
Mine is an LK3054xs, dunno how the wiring differs from the older 3054s.
2021 KYRV (A50324)
2021 KYRV (A50324)
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
2010 Honda Accord Sedan (A50324)
2010 Honda Accord...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
