Kioti LK 3054 sterring leak
   / Kioti LK 3054 sterring leak #1
ElvisnFla
Jacksonville, Fl
Kioti LK3054
I recently purchased a used 1997 LK 3054, with an loader. On my first day of use , It started leaking hydraulic fluid from around the dust seal around the sterring shaft, Also I can pull the sterring wheel up about 4 inches. I have ask several tractor dealers in my area, and know one knows what it could be. Also the closest Kioti dealer is over 50 miles away
   / Kioti LK 3054 sterring leak #2
Did you get a parts manual with the tractor, if so it should show how the steering column is attached to the steering box. Sounds like something let go that holds the column in place.
I wouldn't pull up on the column as you may pull it right out and cause even more damage. Hopefully none has been done so far other than maybe a seal.
Vince, where are you?
Steve
   / Kioti LK 3054 sterring leak #3
</font><font color="blue" class="small">( Vince, where are you? )</font>
Steve,
You sure know how to put the pressure on a person!! /forums/images/graemlins/tongue.gif
   / Kioti LK 3054 sterring leak #4
Jim in Omaha had a post back in 6/24/04 on 3054 loose steering wheel (sorry don't know how to link the post, computers are not my stong point).
Seems the 3054 has a 2 piece steering shaft/with pin
I'll attach a photo supplied by Jon DePratt
No I did not get the book, If anyone has an owners manuel or a repair manuel I would be intrested to buy it from you.
   / Kioti LK 3054 sterring leak #8
</font><font color="blue" class="small">( No I did not get the book, If anyone has an owners manuel or a repair manuel I would be intrested to buy it from you. )</font>
Elvis, check out www.bigtractorsupply.com and get in touch with Dave Williams. He's only 35 miles from Jacksonville, and can probably help get you what you need. Tell him I sent you. John
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2022 JOHN DEERE 6140M LOT NUMBER 264 (A53084)
2022 JOHN DEERE...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2024 John Deere 410R Sprayer (A53342)
2024 John Deere...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
