kioti lk 3054 starting problems
/ kioti lk 3054 starting problems #1
madvetos
hi new member here having trouble with the kioti starting.I turn key and sometimes get nothing, sometimes one click, and sometimes starts strong. I never get grinding or multiple clicks. :confused: thanks for any help.:)
/ kioti lk 3054 starting problems #2
How old is the tractor? Do you leave it out in the rain? For some reason the ign switchs in these don't like to get wet. You might have better luck getting answer if you post in the Kioti forums.
/ kioti lk 3054 starting problems #3
I don't know about the bad ignition switch, but I'll bet it could also be a bad ground or bad cable. So check that too.
Remove the ground from battery and frame and clean connections on both ends super clean. Check both + and - cables to be sure they are good and not corroded.
2025 Kivel Quick Hitch Skid Steer Attachment (A61567)
2025 Kivel Quick...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2012 Ram 1500 4x4...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
