kioti lb1914
   / kioti lb1914 #1
miker2702
Bronze Member
east tenn
bx2200
looking at a 2006 lb1914 with almost 100 hours with loader.
some questions is the loader easily removed? any opinions
on these i know older design etc. i see they are alot heavier
than other tractors of this size enough power? any complaints
with the shuttleshift trans? would it load in a 52" wide trailer.
any help appreciated.
   / kioti lb1914 #2
I have had a lb1914 for five years. It has almost 400 hours on it and I am very satisfied. It was my first piece of equipment of this type so I have had to learn how to operate and have been guilty of all the abuse you read about and the tractor has never given me a problem. The loader has never been off but it looks relatively simple. I have dug rocks, pulled stumps, built roads, plowed snow, dug ditches, installed water tanks, etc... My only complaint is that the bucket is a little down on breakaway force but I'd recommend this tractor to anyone and buy another without hesitation. With a small tractor I think the shuttleshift is a better choice than hydro because it uses less power. The power of the tractor is very good and the only reason I need to use the lowest gears is to control speed, not power.
Bear
   / kioti lb1914 #3
Hi,
I second what Bear has to say about the 1914. I have a 2006 and only have 50 hours so far, but I am amazed at the power that this machine has. I have used it mosly for landscaping and snow removal and it has worked out perfectly for me.
Dave
2013 MACK GU713 (A50854)
2013 MACK GU713...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
