Kioti LB1914 Tachometer INOP
   / Kioti LB1914 Tachometer INOP #1
vewilder
Benson, North Carolina
Kioti LB1914
I bought my first used tractor, so I am new to the workings of a tractor. I am fine working on motors but the diesel thing is new.
I can't find the YouTube videos that I usually find when working on my vehicles.
A few questions on the tachometer and what drives the tachometer.
Does the tachometer run off the cam shaft? If not, what drives the tachometer? What is the proper name if I need to google for a replacement part?
I have pulled the cable and the cable looks fine. The housing the cable sits/screws into has movement from side to side like it is broke.
thanks,
T-bone
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
