Oil & Fuel Kioti LB1914 Oil Pressure Light
   / Kioti LB1914 Oil Pressure Light #1
snagmaster62
My oil pressure light has come on with a slight pulsing in brightness after starting the tractor and does not cycle off. I replaced the oil switch (sensor) with a guage and I am getting readings that agree with the shop manual for oil pressure at idle and when reving the engine. Next I replace the oil switch (sensor) located on the back left side of the engine block and still the light is coming on. What else can be wrong? Does this mean I have a short somewhere in this circuit. Any ideas or suggestions of what else to check would be helpful.
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
