Kioti lb1914 head
   / Kioti lb1914 head #1
Tmar104
1991 kioti lb1914
Need good head for daedong td950b for my 1991,kioti lb1914
   / Kioti lb1914 head #2
Where are you locate and what is wrong with the head?
   / Kioti lb1914 head
Cracked from being overheated.
   / Kioti lb1914 head
Eastman Ga31033. 50 mi south of Macon Ga
   / Kioti lb1914 head
Will kubota d950 head fit my daedong td950b?
   / Kioti lb1914 head #6
I do not know if the Kubota head will work or not. I guess it is possible.
I do have a head on a engine I pulled out of a Kioti LK2554. I don't think it will work either as part numbers appear to be different.
That engine is a TD1300F-1. It probably is close to the same and may even bolt up but have no way of knowing.
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
Quick Kurb Continuous Curbing System with MEGA MARKER (A49461)
Quick Kurb...
2005 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A50854)
2005 INTERNATIONAL...
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
