Kioti LB1914 Cooling
   / Kioti LB1914 Cooling #1
mlaird
Kioti
Trying to change coolant on a 2008 Kioti 1914 and can't locate the drain cock. The manual says on the right side, but I can't find one any where. Any clue?
Mike
   / Kioti LB1914 Cooling #2
My 3054xs's radiator drain is on the right frame rail, just ahead of the oil filter; looks to be an aluminum "T". There is no apparent drain oriface, but when loosened, it drains behind the fitting. Don't know if your's is similar
   / Kioti LB1914 Cooling #3
Right side if you are sitting on tractor
OR left side looking at it
Brass fitting from frame
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2013 Dodge Charger Passenger Car (A51694)
2013 Dodge Charger...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
