kioti kb2385 back hoe - Hydro leak where rod enters body
   / kioti kb2385 back hoe - Hydro leak where rod enters body #1
buyerjohn
Berkshires, MA
DK45s with cab
   / kioti kb2385 back hoe - Hydro leak where rod enters body #2
You will not know until you tear it down or someone tears it down. Just might need seals or a new rod
Well, just how close are the measurements from pin to pin?
Is the stroke the same?
Is pin size the same?
thanks for the quick reply...the overall pin to pin closed distance is within 3/4", stroke is the same, shaft and bore are the same - I was hoping to avoid removing the cylinder to determine the existing pin size. The pin size is the only spec that's not easy to measure on the existing part so was hoping someone else had the same issue.
Kioti replacement is 3 times more expensive and I'm not sure if that's because the pin connections are customized.
Vehicle Seats (A51695)
Dozer Blade Attachment (A53117)
Dozer Blade...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
43030 (A51691)
43030 (A51691)
