Kioti Injection Pump Failure Data
   / Kioti Injection Pump Failure Data #1
ritcheyvs
Veteran Member
Kittrell, NC
Kioti DK45S
Fellow Kioti owners and operators. Multiple injection pump failures have been reported on this site so I'd like to start a survey to collect data on these costly and frustrating failures. This information will be most useful if you respond only after your failure is completely resolved. Also, please advise if there are other data that should be added to this list. I hope collecting this information in one place will benefit everyone in our pack. As I receive this data, I'll consolidate it in a spreadsheet at: http://kittrellcommunitywatch.dyndns.org/Kioti_IP_Data.htm
If your Kioti injection pump had a confirmed failure, please respond with the following data as known:
(1) Tractor Model
(2) Year built
(3) First 4 digits of serial number
(3a) Stop solenoid style (old or new)*
(4) Approximate operating hours at time of failure
(5) Nature of failure (if known, e.g. jammed tack, stripped gears, excessive plungrr wear, etc)
(6) Corrective action (e.g. new IP, local IP rebuild, etc.)
(7) Did Kioti cover any of the cost (e.g. under warranty)
(8) Approximate failure-free hours since failure
* The old style stop solenoid is external and operates on the manual stop linkage on the cover plate just below the injection pump. The new style stop solenoid is mounted on the front of the engine; the cover plate just below the injection pump also serves as the oil fill port. If you prefer, send me your full serial number by private message and I will identify your configuration.
   / Kioti Injection Pump Failure Data #2
(1) Tractor Model
(2) Year built
You should be able to use 1-3 above to determine from the online oem parts websites which stop solenoids are on the tractors with failed IP pumps. Can't get rid of a gut feeling that the newer style SS (e.g. rod on end of SS that directly pushes through a plastic guide which in turn has a tip that pushes IP rack pin in off position when key is turned off) is still not at fault.
The old style had a start spring attached to fuel cham shaft gear and fork lever 1 to start engine and had the SS attached by a support bracket to front of IP cover to stop engine by means of rod pushing on extenal lever which would in turn move an internal stop lever to move IP rack. Thus you would not have the IP rack receiving the direct and violent action of the SS rod. I would really like to see Bocsh/kioti enginneers comment on this.
This is the only thing I would add in collecting data for this problem.
Hope you will get alot of response so can shed some light on this problem.
   / Kioti Injection Pump Failure Data #3
Asa far as I could tell by reading many of the previous posts on pump failures, the IP issues looked like it was mostly the 2006-2008 models.
   / Kioti Injection Pump Failure Data #4
If I am reading the serial number correctly on oem parts websites it looks like (at least for my DK45S tractor) that the new SS style started on 2005 C44 models with serial numbers 00209 and up. So that would definitely handle the 2006-2008 years. My tractor is 2006 C44 and definitely has the new style SS.
Thanks for suggestion. I think I modified the data request accordingly. I have the "new" SS design on my tractor so I'm a little unclear how the old version operates. As near as I can tell from the documentation, the "old" design uses a manual lever on a shaft that goes through the cover plate with a lever on the inside that pushes directly on the rack pin, with the electrical solenoid operating directly on that shaft. I didn't see any spring that might absorb the shock of the solenoid's action. Am I missing something? Is the solenoid force low enough to avoid gear damage? I guess I assumed that the SS shutoff spring in the new design would be spec'd strong enough to overcome the throttle spring but weak enough to avoid IP gear damage (and springs don't generally get stronger with age). But maybe I don't understand
   / Kioti Injection Pump Failure Data #6
The spring I was referring to (on old style) is shown as a start spring attached on one end to the fuel cam shaft gear and attached on the other end to the fork lever and is only relevent to starting(as far as I can tell). I just thought that would help explain difference between old and new style.
I think I said basically the same thing about how old style stopped the engine. The point being that the old style works more like a manual shutoff ( i think) with less force being applied to IP rack.
From what I read(page 2-40 in ex manual) the only thing the SS has to overcome is the idle spring located in the idle adjust bolt when tractor would be at idle before shut off. When I had idle adjust bolt out when removing IP, it's spring tension ,by hand, is much much less than the spring tension, by hand, on the SS. I cannot find anything that talks about SS needing to overcome throttle(i.e. governor spring), but maybe I missed something. Also the start spring is located on my tractor in the idle adjust bolt not on fuel camshaft gear and fork lever.
Bottom line for me is: old style used different method to act upon IP rack to start and stop engine than new style, (which seems to me to be harsher on IP rack). I could be wrong and that would be fine because I would like repaired or new IP to out live me.
   / Kioti Injection Pump Failure Data #7
2006 CK25
New style pump
failed at ~320 hours - stuck open full throttle
Kioti replaced under warranty
Gittyup: Thanks data has been added to online spreadsheet.
   / Kioti Injection Pump Failure Data #9
tractor just died spins but wont fire, called Kioti dealer who thinks the pump is dead, keep u all posted on warranty stuff
   / Kioti Injection Pump Failure Data #10
2 pumps for me!!! 1st one gears broken...covered under warranty. 2nd one rod jammed in bore....i paid for this one. Kioti didnt want to hear it. My tractor is a 2006 CK25. Stop solenoid is new version. 1st failure was at 300-400 hours......2nd failure was at 925 hours.
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
2010 Ford F-150 (A50323)
2010 Ford F-150...
