Kioti hydraulic quick attach
   / Kioti hydraulic quick attach #1
lilyperch
Bronze Member
Herrick, IL
2016 Kioti NX4510 HST Cab Backhoe
Anyone know if a hydraulic quick attach for FEL attachments exists or how to make one??
   / Kioti hydraulic quick attach #2
I think electric actuators would be better suited for this project. Building something wouldn't be very difficult, but powering the hydraulics would be bigger project.
   / Kioti hydraulic quick attach #3
Yes they do exist on many of the bigger farm and construction equipment. Try checking with you JD, case, CAT dealers and others. It usually on the bigger equipment, but might be adaptable. On the down side you wont know if your hooked up correctly sitting in the seat.
Quick Attach | Thomson Electric Linear Actuators
   / Kioti hydraulic quick attach #4
There is someone on here that has did one with linear actuators I believe it was "Fallon". On a Kubota. I haven't learned how to add a link to another thread here quite yet. Search quick attach SSQA I think.
   / Kioti hydraulic quick attach #6
All you have to do is once your connected to the bucket or forks or what ever is raise them high enough to see the latch close. Wouldn't be hard at all to use a small hydraulic cylinder or electric actuator with the single latch lever. You could even run a set of small hoses from a rear remote to operate it. Kioti only shows two rear remotes available but 3 will fit on a nx
   / Kioti hydraulic quick attach #7
I wonder if this is even a good idea? I don't change SSQA stuff that often but I like to visually confirm the bottom lock bolts went through the holes.
   / Kioti hydraulic quick attach #8
I've been using my hydraulic QA for about a year, never had an issue with locking pins failing to engage. Just tilt the loader back a little, actuate the valve, listen for the now-familiar "clunk". I usually raise the loader a bit to get a visual confirmation anyway. But have not had any surprises.
   / Kioti hydraulic quick attach #9
Did you make it yourself - photos please.
   / Kioti hydraulic quick attach #10
I always check too, but you can see them from the seat if you raise the loader a bit. I have thought about it, and there are a couple of threads where guys have made them, but I just haven't seen the need. I sometimes change buckests/grapple/forks several times a day, but it just takes a minute to jump off and back on.
2015 DODGE RAM...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2015 CATERPILLAR 926M WHEEL LOADER (A51242)
2015 CATERPILLAR...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
12in Backhoe Bucket (A52128)
12in Backhoe...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
