Kioti Fluid Examples
   / Kioti Fluid Examples #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I spoke to kioti, and as of last week they have updated some fluid info that will reflex in the owner manual which will show the following example of fluid to use. Figured I would pass them on.
Engine Oil Recommendations:
Choose an oil with an SAE rating of CC, CD or higher.
Below 32 degrees F SAE 10W-30
Above 32 degrees F SAE 15W-40
Examples of brands:
Valvoline Premium Blue 15W-40
Chevron Delo 400 15W-40
Castrol Tection HD 10W-30 , 15W-40
Pennzoil Long Life HD 10W-30, 15W-40
Quaker State Universal HDX 10W-30, 15W-40
Hope this is helpful.
Thank you.
Any universal tractor fluid rated for differentials, final drives, wet brakes, and hydraulic systems enclosed in a common reservoir. Some brand names suggested are:
Texaco TDH Oil
Exxon Hydraul 560
Exxon Torque Fluid 56
Pennzoil Hydra Tranz
Mobilfluid 424
Thanks!
   / Kioti Fluid Examples #2
Yeah, but this recommendations are for Kioti's. Bobcat manuals only recommend Bobcat brand fluid, and do not mention specs for cross referencing. Do you think the different paint on the outside would cause it to need different oils inside?
   / Kioti Fluid Examples #3
Oh most definitely!
The different paint causes a chain chemical reaction with the molecular structure of the petroleum distillate product in the engine and transmission systems.
Also, the Bobcat stickers are altering the gravitational force with the adhesive power and that cross-checks the internal friction bond with the metallurgical friction coefficient adhesive strengths.
Got that?
   / Kioti Fluid Examples #4
I was a traitor. I love my Bobcat CT225 so much I decided to get another bigger one. I was dealing on a CT450, but bought it in red with McCormick stickers on it. Now you tell me I'll need different fluids again if it's painted red instead of white or orange. I guess the $3000 savings can help me deal with the different fluids for different color Daedong tractors. :(
   / Kioti Fluid Examples #5
Oh definitely...do I need to elaborate again???
   / Kioti Fluid Examples #6
You should post some pics of that red version of the Kioti/Bobcat machine. Love to see it. You better go out and buy an even bigger blue version too.
Lets see some pics of the red one
   / Kioti Fluid Examples #8
well HK, here is my red CT450.
nice looks great. I just seen that was you that asked about my 450 if i was going to sell it.If i would of looked sooner i would of got back to you on that. I really don't use it that much so i was up in the air about selling it.
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
CAT 973 (A47384)
CAT 973 (A47384)
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
Caterpillar CB-54 XW (A50120)
Caterpillar CB-54...
