Mowing Kioti finishing mower, grease fittings . . .
   / Kioti finishing mower, grease fittings . . . #1
mark.r
Platinum Member
Leesburg, VA
Kioti DK45SE
I have this thread going: http://www.tractorbynet.com/forums/...hreading-hole-grease-fitting.html#post1168930
and it has been somewhat helpful but not completely. I need to rethread a hole for a grease fitting on my Kioti finishing mower. Problem is I am not sure if it is a straight metric thread or is it tapered. The dealership offered to come by the house and retap it Sat. morning for me but I have access to a standard Lowes issue tap set with a 6mm x 1 tap which I am assuming is what I need. If so I was going to go ahead and do it tonight. Anyone have knowledge in this area?
   / Kioti finishing mower, grease fittings . . . #2
The hole isn't tapered, the fitting is.
It's an Italian thing......
BTI
BTI
Ah, so a 6 or 8 mm tap from HD or Lowes should fit the bill then?
An 8mm tap from Lowes did the job. Worked like a charm. Thanks for all the help.
Huskee 20 Ton Wood Splitter (A51573)
Huskee 20 Ton Wood...
Ex Mark Zero Turn (A51573)
Ex Mark Zero Turn...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
