Kioti Factory Cab
   / Kioti Factory Cab #1
dae06
Minnesota
Kubota B2650
I'm dealing with a Kioti dealer that is now telling me the CK2610 tractor does not have an option for the "Factory" cab. He said it only has the field cab option and will not have A/C. Unless I'm reading things wrong, I've see many posts regarding factory cabs on the CK2610's.
My goal was to price out tractors with:
1. Factory cab
2. Front End Loader
Looking for quotes on:
CK2510
CK2610
CK3510
Anyone know for sure or even may own a CK2610 with a factory cab?
   / Kioti Factory Cab #2
quick look at The Kioti web site has me reading that the CK2610 is available with the field cab as an option.
A quick look at the accessories page
Field Option Cabs | Kioti Tractors
shows the options that come with the field cab and they apparently only have "forced air heat" but does not list air conditioning as a feature
   / Kioti Factory Cab #3
Looking at the website, NONE of the base CK models have a 'Factory Cab' (by 'Factory Cab', I'm assuming you mean w/ Heat and A/C?), though you can get the Field Cab (heat only) on any of the CK models.
If you want a factory cab on a CK, I think you need to go with the CK3510SE HC.
Tip - Early versions of the CK3510SE HC had a Live PTO, while they all now have a Independant PTO. If you can find one with the Live PTO (my dealer had one on his lot - look for the extra pedal on the left side) and don't care to have the Independant PTO, you might be able to use that as a negotiating point to talk down the price.
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
