Kioti DK65s
/ Kioti DK65s #1
Topbanana
Troy, Michigan
Kioti DK65S
Where s the PTO safety relay. Im trying to trace why the tractor will not start. Thanks
/ Kioti DK65s #2
Do you have a mid PTO lever directly in front of the seat? Even if you have no mid-PTO installed the lever could be in the "on" position causing a no-start. It happened to me.
I do not have the DK service manual, but on NX series tractors, the PTO relay is one of the relays on the fuse box located (as you sit on the tractor) on the forward right side corner of the fuse box. The fuse box itself is (on an NX) mounted on top of the lefthand bulkhead just to the left of the driver's seat. There is also a group of relays mounted on the forward firewall above the radiator under the hood.
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
Killbros 390 Gravity Wagon (A66285)
Killbros 390...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
