Kioti DK65S - 15' Bushhog
   / Kioti DK65S - 15' Bushhog #1
land66
Can a Kioti DK65S handle a 15' Bushhog mower?
   / Kioti DK65S - 15' Bushhog #2
Here is what someone posted in another thread...
"I have a dk55c that has 120 hours now. No problems at all. I use it this weekend to pull a 15 foot terain king batwing mower and it worked very well. Air conditioning is very good. I am in west texas"
I would make sure your dealer does size the proper cutter to the tractor.
Different manufactures of cutter require different pto hp.
I am sure you will be able to find one that will work for your needs.
I willl be happy to do the search for you if you are interested.
Rick
Thank you for the offer. The dealer is suggesting a Woods 15 foot mower instead of Bush hog. I tested the DK65s this weekend with a Woods 10 foot mower and it did fine other than the fact that the tractor got hot several times, one time in the red. It was about 95 degrees and I was cutting pretty thick sunflower. I have a real concern this tractor will handle the Woods 15 foot bat wing cutter in normal conditions.
   / Kioti DK65S - 15' Bushhog #4
I have customs that use 15 foot Woods and does well, in real heavy grass it will pull down some.
   / Kioti DK65S - 15' Bushhog #5
I have the DK65 with a 15' batwing made by Taylorway. Like one of the guys said above, it will pull down in thick grass, but you just downshift. I generally go in high range, gears 1-4 depending on the height and thickness of the growth, on level ground. I have not noticed the tractor indicating any heating problems, although one time when i stopped, there was a twig smoldering next to the exhaust stack. After pulling it out and burning my finger, I figured there had been a good deal of heat put out by the motor, but the cooling system was keeping up fine.
Oh yeah, of course the AC was one and it was a very hot day. For my money, I decided to downshift in the thick stuff rather than pay a fortune for a tractor that could loaf through it, but be too much for everything else.
I was concerned with the pto switch/solenoid being too sudden (being used to manual clutches that you can slowly play out, like an old John Deere), but it seems to work just fine if you engage/disengage in idle.
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2024 BOBCAT T770 SKID STEER (A51246)
2024 BOBCAT T770...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
2019 JOHN DEERE 560M LOT IDENTIFIER 28 (A53084)
2019 JOHN DEERE...
