Kioti DK55 Glow Plugs
   / Kioti DK55 Glow Plugs #1
jvanbrewski
Tuttle, Oklahoma
2005 Kioti DK55, 1985 Shibaura SD2243
Recently, I had a glow plug go bad in my tractor. I called the dealer, and they had 1, and wanted $49.95 for it! I couldn't beleive it, as I was considering replacing all of them. For those of you that are dealers, I realize that you have to stay in business, but come on! $50 for a $8 part? So, being the resourceful individual I am, I went seeking replacements. The glow plug is manufactured by Beru, world leader in glow plugs. Here is the message I got directly from them regarding the 0100 226 393 11v that is in this tractor: "Unfortunately this glow plug was taken out of our program some time ago and we do not offer any replacements". (lovely!) I did some extensive research, and found that the NGK's Y106-v Will fit into the combustion chamber, and will seat correctly. The only problem is that they are about 3/4" shorter. That means that you can't use the bus bar for the electrical connections, so I made some jumpers out of #6 wire and crimp terminals. Make sure you thread the knurled nut that comes with them, all the way down to the bottom, and add your electrical connections on top of that. The Kioti hardware that came off of the old glow plugs fit the new ones. Works Great! And, I bought them at O'Reilly Auto parts for the $8 I mentioned above. I'm sure there may be other cross reference's that may work, but this was my success.
Also, make sure if you replace the OEM oil filter with a Wix, use the 51324. The 51182 works as well, but is longer, and you won't be able to get the side engine cover on. (Real experience)
   / Kioti DK55 Glow Plugs #2
thanks for the info i have the same tractor, someday i will have to do the same thing.
   / Kioti DK55 Glow Plugs #3
Purchase a $50 engine block heater. Install. The glow plugs will become a non necessity then. Your tractor will purr upon start up, and run as if it is summer time.
   / Kioti DK55 Glow Plugs #4
where do you get the block heater and what model fits the kioti dk55? is it a big job to install... ?? thanks
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2018 Dodge Ram 4500 4x4 Enclosed Service Truck (A48081)
2018 Dodge Ram...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A48081)
2005 Toyota Tundra...
2017 Crane Carrier Co LET2 Side Loader Garbage Truck (A48081)
2017 Crane Carrier...
2007 GMC C7500 Elliott ECH-3-65-CHA 60ft Sign Boom/ Bucket Truck (A48081)
2007 GMC C7500...
