East Coaster
- Joined
- Oct 10, 2019
- Messages
- 1
- Tractor
- kioti, AC, White
Has anyone had issues with the diode across the 4X4 solenoid in Kioti tractors. I have an interesting intermittent problem with a 2006 DK45S. I have a fair amount of experience with electrical issues but this one does have me stumped. This started with the fuse blowing intermittently when in 4 wheel drive. If I unplug the solenoid, the fuse would still blow. I replaced the 4 X 4 switch as well.
A side note here, the solenoid shows 30 ohms, the dealers here could not tell me what impedance this coil should be. should anyone knows this value that would be great.
A second note. On this tractor the 4 wheel solenoid and the PTO are on separate fuses. So the PTO circuit should not be an issue.
This is what I have discovered. The fuse panel on this tractor is under the left side floorboard. I found that the plastic amour protecting the wires coming out of the fuse box had slipped back and the conductors of several wires were showing, including the 4 x 4 wires. After insulating these wires and confident the problem was solved, the next use of the 4 wheel drive blew another fuse. I tried another fuse to determine when this blew and if I lost the fuse with the solenoid unplugged. Yes, it blew however it did not blow immediately, I lost power within an hour.
At this point I was convinced I was chasing another bare wire. I disassembled the tractor so I could unwrap the harness. I did not find any issues with wiring. I have a schematic and knew there was a a connection to the indicator light on the instrument panel separate from the switch light mounted on the fender. I disconnected this circuit,on the switch side, for the reason when I was testing the circuit again I noticed this light flickering. If the problem was in the instrument panel I wanted to eliminate the circuit.
The intermittent problem still exists. There is a diode across the solenoid circuit. When cold, this diode tests correctly with a meter. In that it blocks the electrical flow in one direction and shows 0 resistance in the other.
My question is has anyone experienced issues with this diode when it heats up?
The other possibility I am considering is if the bared wires coming from the fuse panel are now undersized for the current load. although I do not see any sign of overheating.
I am at a loss with this one, it seems like an easy fix, however I have been at this for a while with little success.
Any suggestions would be appreciated.
