duttymaxx
I have a 2016 Kioti DK 4510 Hydro shuttle with 627 hours on the clock, when I parked it 3 days ago everything is fine. Today I go out to start it, when I cycled the key it I could hear a couple of relays clicking but it wouldn稚 do anything as far as turning over, the gauges were going crazy and every warning indicator was flashing, on the hour meter I seen Error 2 and Error 6 and 7 scroll across. Battery was charged to 12.7 volts And when I have a volt meter hooked to it and try to start it the voltage would plummet to 6 volts. All the fuses checked out and APPEAR to be operational. The main relay that was making the clicking noise I checked and it ohmed out, however when I disconnect the relay, that I am assuming is main ignition relay?? The brand is Handouk and the number on it is RV7-12-6STM-D 70amp 14dc, obliviously the clicking would stop and also the gauges would stabilize and no warning indicators other than the normal during startup it still wouldn稚 start, I would assume cause the relay was removed. I have found a replacement relay on eBay for $25, but not sure how deep I should dig into it before taking it to the dealer, it should still be under warranty, I知 assuming the 6 year unlimited power train warranty would cover this.
anyhow I知 rambling now, if anyone has had a similar experience I would love to hear your experience with it.
