kioti dk45 hydraulic is making bumping noises
/ kioti dk45 hydraulic is making bumping noises #1
robert tiller
when i raise the box blade up it makes bumping noises and you can let it down some and it will quit. also if the draft is all the way up you cant let blade down with position lever. Any help or a phone call would be appreciated .tractor has 369 hours on it.dealer 100 miles away says it can be adjusted with a screw under seat
/ kioti dk45 hydraulic is making bumping noises #2
Mine does the same thing...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
2023 BOBCAT E88 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E88...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2020 CATERPILLAR 323 EXCAVATOR (A60429)
2020 CATERPILLAR...
