Kioti DK35
   / Kioti DK35 #1
3gGT01
Bastrop, TX
Kioti DK35
Hi Folks!
I have a DK35 and have put exactly 200 hours on it. The IP middle gear broke some teeth. The tractor has been down since Sept. 2015. At that time I got as far as figuring out the IP rack was hanging and it wouldn't start unless I moved the rack over towards the right. I went on vacation and just never fixed it. I'm finally at the point where I have to have it running, so here I am. I ordered 3 new gears from Conestoga Diesel Injection, but I believe I have the plungers turned 180 degrees from where they should be. The tractor engine is running wide open. I will check the plungers tomorrow and likely rotate them 180 degrees and test it out again.
~Tom
   / Kioti DK35 #2
G'day Mate and welcome to TBN from Downunder.
Enjoy the site and good luck with your repair.
   / Kioti DK35
Thanks Wagtail! Kind of neat to hear you are from Tasmania!
~Tom
   / Kioti DK35
Good news, I rotated the IP plungers 180 degrees and the tractor is working great. With the IP slides/roller stop pins facing upward, the plunger slots must face to the left with the slide rail in the middle of its travel.
~Tom
   / Kioti DK35 #6
~Tom
Welcome to TBN Tom, with your mechanical knowledge we can sure use you on the Kioti forum.:thumbsup::)
   / Kioti DK35
Thanks Murph! Wow, 19,940 post by you. Holy cow, that's a bunch. :thumbsup:
   / Kioti DK35
Thanks grsthegreat!
~Tom
   / Kioti DK35 #10
Do you know what year your tractor is ?
Is it a DK 35SE model ?
Just curious, because so far it seems to be only certain years (2005-2008) that have had the IP issues.
Glad to hear you got it going.
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
