Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive
   / Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive #1
Sjj123
Kioti DK 5010
So I've taken off 100 bolts to raise the platform to get to the shifting boot (1-4 gears) behind the gas tank. Can anyone help with a parts diagram or likely explanation as to what has deteriorated. I believe I understand that the boot is a dust cover and if leaking at this location a seal of some sort has failed?
Sj
NY
Wel...I learned that the shift boots are part # T-5715-21383 (same part for right and left),,,,leakage through the shifter can be tempered with Permatics Black Ultra Silicone
and a serial number starting w/ P = 2014 model
The amount of stuff one has to take off to reach the right shift lever boot is over the top
   / Kioti dk 5010 Hydraulic leak at shift lever boot? Clutch drive #3
My dk5510 leaking as well. Traced leak to what I believe is the source, the shifter boot. I just went through the painful process of removing and it’s definitely shot. Curious if replacing this part resolved your issue?
Test Button (A47477)
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2011 PROCO 130BBL ALUMINUM VAC TRAILER (A53843)
2011 PROCO 130BBL...
