Kioti DK 35 SEH wiring
   / Kioti DK 35 SEH wiring #1
BDougherty
Bargersville, IN
Kioti DK35 HSE
Hello,
I damaged most of the wiring on my tractor right at the quick connections between the main wiring harness and the right rear fender harness. The damage was concentrated to the wiring for a single plug. I have elected to hard wire those wires together. In doing this I have a couple of issues.
-pto will not engage (light comes on at the dash, tractor won't start with the switch on but the pto won't turn.
-cruise control engages but will not disengage without turning off the key.
I did find two wires marked identical (black with a green stripe) with the damage there was no way to tell which wires matched up. I have tried both combinations of hardwiring those wires but get the same results.
Any suggestions to trouble shoot this issue. I am not very experienced with chasing electrical issue like this so please go easy on this rookie.
Thanks in advance!!
Bryan
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2007 Mauldin MT-500 T/A Tack Trailer (A49461)
2007 Mauldin...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
