Kioti CK3510 vs LS XR3135
   / Kioti CK3510 vs LS XR3135 #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
Thinking of possibly trading my CK3510 in for a cab model. I知 not sure if I should go with the CK3510 cab or the XR3135 cab from LS. I致e read a little on LS having some issues but I understand all companies have issues. Both these tractors would definitely fit my needs but just wondering the pro痴 and cons痴 When comparing them. Should I steer clear from LS? Mainly asking because after checking them both out in person I kinda like the LS cab set up a little more. A few years back when shopping I test drove a LS and it went into limp mode. I never knew what caused it as I just ended up leaving the dealers. So again I知 a little nervous with LS.
Both LS and Kioti will cost me about the same with my trade in so the money won稚 be a factor.
   / Kioti CK3510 vs LS XR3135 #2
I would think they are about even. Most owners seem to be pretty happy. LS has been the darling for the last few years. Perhaps that is wearing off.
   / Kioti CK3510 vs LS XR3135 #3
My honest opinion would be to buy the one you like best and are the most comfortable on.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
John Deere X530 (A51573)
John Deere X530...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
