jacobsdaddy06
Bronze Member
Looking at kioti hard and these are the 2 that I'm trying to compare, what if any are the main differences between these 2 models? Thanks
B
But I would however recomend looking at the DK40 if you decide on the larger frame. If it isnt too much more money, it has a MUCH better loader than the DK35. It is only about 200lbs heavier than the DK35. Roughly the same size tractor unlike the CK35 vs the DK35. But the loader can lift ~2700lbs vs the ~1400 of the DK35 vs the ~1100 of the CK35. Again, MUCH stronger loader by going up only one notch, and the little extra power is always a plus too.
Now that you have used the 40 for a while, can you tell how your DK 40 is doing on fuel compared to the 35.I agree, the DK-40 is it!:thumbsup:
Had a DK-35 for about a year and traded it in for the DK-40.
The 40 also has an extra cylinder over the DK-35.
If you can afford the 40 go for it- you will NOT be disappointed.
Thanks for the reply.Hope that helps answer your question. Are you considering going up to a 40?
