Old thread but may be useful to someone else. 2006 CK30 HST.
My alternator light was glowing which means no charge. Tested and only read 12.2 volts. Removed the alternator and mostly dismantled but can't get the back (with inbuilt regulator) off it. I'm picking the rear bearing is just tight in the housing. Don't want to wreck it. I will soak a bit of CRC in there and see if that helps.
A bit disappointed as it is just a bit over 600 hours and a alternator in this situation should last a lot longer. (I am a retired mechanic)
Will update if I have some success. Hoping the brushes are just stuck but probably hoping for too much.
Might be a new one coming up. I was just checking my little 'Panther ' over for the coming mowing season. Bad timing.
