Kioti CK2610SE for Finish Mowing?
   / Kioti CK2610SE for Finish Mowing? #1
JHallett
Nova Scotia, Canada
Kioti CK2610SE
I have a few acres of lawn on a 7-9° degree pitch I need to mow along the pitch. My CK2610 has R14 tires, moderately loaded with 2” spacers and I am located in Nova Scotia, Canada. I am reading that anything over a 60” finish mower is likely to be underpowered by the CK2610 and I am a bit concerned that the weight of the tractor cutting on a 7-9° degree pitch will tear up the turf. The cost of a good finish mower is getting close to a zero turn, but ZT would add a bit more to the servicing and storage. Then there are also flail mowers to consider which apparently takes less power so I might go up to a 72” - can they do a good job if kept sharp and equipped with anti-scalp rollers etc.?
Be interested to hear the experience of other owners using the CK2610 for finish mowing.
   / Kioti CK2610SE for Finish Mowing? #2
My previous tractor (JD 850) was 25 HP , 22 PTO HP and it ran a 72" finish mower fine.
   / Kioti CK2610SE for Finish Mowing? #3
My current LS 25hp (same physical size as the 2610) runs a 72" finish mower without any problems whatsoever. I have actually used the finish mower to cut rough field grass without issue.
No it has to be dry and can't be too tall (over a foot-16"), otherwise you have to slow down a bit.
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
Homemade Hunting Blind (A50515)
Homemade Hunting...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
