Kioti ck third function
   / Kioti ck third function #1
maximus1277
Manchester CT
2010 KUBOTA B2320, 2010 KIOTI CK27, Kubota L3940,JD110 TLB
I just picked up a quick attach snow plow and a grapple for my ck27. My local dealer recommends that I control the front hydraulics from the A/B valve on the right side of the seat. I have never seen it done that way, and I'm not sure what that exactly involves since I didn't get the details yet, but the cost is half of those fancy push button joystick valves I've seen around. Ideally, I want to keep the cost to a minimum as I suspect I will be shopping for a bigger machine in a year or two. Another way to go I guess would be to run lines from the rear ports thru some sort of a log splitter valve. Anyone using the side A/B valve that can comment on usability and experience? I'm not planning to use the plow all that much and the grapple will likely see usage once a year.
   / Kioti ck third function #2
You have the control valve now, That is what the lever should be at the right. The lever springs back to center when you let go? All you need are a couple of 11' hoses and some couplers and you can be up and operating.
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
