Kioti CK 30H housing LH ou RH bolts?
   / Kioti CK 30H housing LH ou RH bolts? #1
Denislp
Quebec
Kioti CK30 2013 w Backhoe
Hi, I have a CK 30H splitted in two parts and the mechanic stripped 5 out of 6 bolts. Can somenone tell me if the housing bolts are LH ou RH? Thanks everyone, DP
   / Kioti CK 30H housing LH ou RH bolts? #2
I would think RH. The mechanic should know if he stripped out 5 of 6. I would be more concerned with a mechanic that managed to strip out 5 bolts and what stripped, the bolts or the housing. 1 is 1 too many.
   / Kioti CK 30H housing LH ou RH bolts? #3
Let me see...Bolts probaby RH, but housing is aluminum, and "mechannic" probably used pneumatic impact gun to tighten bolts....
If housing is aluminum, and threads truely stripped, you may be able to salvage housing by having "thread inserts" installed by reputable shop and send "mechanic" bill for repairs then FIRE HIM...
Thanks for your answer, I appreciate!
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
PumpJack Brand Pump Jack (A55218)
PumpJack Brand...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
