Kioti CK 20s Hydro Question
   / Kioti CK 20s Hydro Question #1
Darrel
Southern Illinois
08 Kioti CK 20 S Hydro
Hi everyone, I am a newbee to the this sight. I just bought a new 2008 Kioti CK 20s Hydro with a FEL KL 120 and KMR03 60" finish mower last week. My son has a Kioti and is very pleased with it so I thought I would get one also. I did not know if I should get the stick or hydro and this sight made up my mind, nearly everyone said get the hydro and I love it. I do have a question maybe someone can answer.When I tried out the mower the other day I pushed in the clutch and put the pto in gear and begain mowing ,workes great .However when I pushed in the clutch to disengage the pto it sounds like all heck is tearing up.I called the dealer and he said that is normal.My son has the stick and he says he can't remember his making that kind of noise is this something to do with the Hydro? Has anyone had the same sounds when stopping the pto or is there something I need to do different. Thanks for any help .
   / Kioti CK 20s Hydro Question #2
Mine is quiet. I just use the clutch like you say.
   / Kioti CK 20s Hydro Question #3
Hi also have the CK20HST and mine makes all kinds of noise. I just engage and disengage the PTO quickly. Not much noise that way.
   / Kioti CK 20s Hydro Question #4
That noise is the over-running clutch in the transmission. It keeps the momentum of a rear implement from running the tractor transmission. Nothing to worry about, the clicking is the over-running ratchet. It's just doing it's job.
Hope that helps
   / Kioti CK 20s Hydro Question #5
I don't use the clutch to disengage the rear PTO. The only attachment I use is a rear mount snow blower with PTO drive shaft and when I want to stop it, I just pull the lever into the off position. It's smooth and easy, I don't need to stop and clutch, and there is no over-running clutch ratcheting. I guess if I needed to stop the propeller quicker, I would push in the clutch so the device would slow it down quicker but that has not happened yet.
Thanks to everyone that answered my question.I was just concerned that something was wrong or I was doing something wrong.I will just go ahead and enjoy my Kioti. Thanks Again Everyone
   / Kioti CK 20s Hydro Question #7
That's very interesting. I also have a CK20 with a rear finish mower that causes this noise. I say "causes" because I also have a rear mounted bushhog and tiller as well and neather cause this sound to happen. All are run from the rear pto. Strange.
Poladin Hydraulic Trencher for Skid Steer (A47384)
Poladin Hydraulic...
Case SR240 Skid Steer Loader (A50514)
Case SR240 Skid...
Paladin Hydraulic SFB 500 Breaker (A47384)
Paladin Hydraulic...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
Toro TRX 46'' Ditch (A47384)
Toro TRX 46''...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
