Kioti Air Filter
   / Kioti Air Filter #1
boomer613
Northern part of AL
Kioti DK40SE /W FEL
From my understanding an air filter for the Kioti 41HP engine cost about $55. This seems a bit high for something that cost about $3 to make. A friend of mine buys a car filter from auto parts store for his Yanmar. Has anyone found a similar air filter for Kioti engine at an auto parts store? And does anyone have any objection to use a car air filter if you can find one that matches pretty close? I know I will be replacing one or two every year due to all the dust and sage grass on my property.
Has anyone found a cheaper Kioti air filter online vs. at the dearship?
   / Kioti Air Filter #2
Diesels swallow HUGE amounts of air; shouldn't go cheap on engine air filters, especially in really dusty conditions
   / Kioti Air Filter #3
How are they different?
   / Kioti Air Filter #4
I believe you can get a second inner filter to the big one. I would try getting the inner filter then just re-use the outer one and clean it out every so often. Then if you damage the outer filter you still won't get dust into the motor.
   / Kioti Air Filter #5
Did you ever think about using a K&N filter? It's washable and reuseable. My Kioti part number is E7230-11081 and it's made by Donaldson with their part number of P822768 marked on the end of the filter. I checked and believe that your DK40se uses the same filter. I used the K&N cross chart from their site. K&N High Performance Lifetime Aftermarket Air Filters - Automotive and Motorcycle Air Filters
This is the one I have for my CK30hst and the cheapest place to purchase that I found. K&N E-4962 Replacement Industrial Air Filter | AJUSA.com
You'll need the recharge oil and cleaner but it still ends up cheaper than the factory filters. I imagine any good grease and dirt cleaner would work in place of their cleaner. There is some down time for cleaning but at this price, you could get two and have no down time. Their site also explains how to clean the filter. Just a thought being that you mentioned the frequency that you'll need to change the filter.
   / Kioti Air Filter
Pretty intesting! So it is washable and lifetime? How long have you used in your CK30 and do you view it as a comparable or better air filter?
   / Kioti Air Filter #7
I look at it this way. What is a $55 air filter to a $12,000 diesel engine. Some of you guys may want to cut corners but mine gets replaced with the Donaldson air filter every 100 hours if it needs it or not.
   / Kioti Air Filter #8
Looks like my post disappeared. If you read your manual, you will see that the filter is meant to be removed daily in dusty conditions and cleaned. It isnt like throw away car filters, it is semi-permanent. You owners manual will or should describe how to remove the outer filter (some tractor have an inner filter and the housing has to be built for inner and outer filter, you cant just put one inside the other one) dump the dust cup, unscrew the wing nut and pull out the outer filter, tap gently on the tractor tire to remove the excess dirt from the pleats. If you have compressed air, blow the dust out by blowing on the outside of the filter, blowing out each pleat, then reinstall being carefull to make sure it is seated properly. The outer filter should last several years if you dont damage the seal or tear the paper or get it wet. You dont need a high dollar K&N filter kit, it already has a cleanable filter designed specifically for the tractor operating conditions meaning dusty conditions and grassy fields. Some higher end tractors will have the same litttle gizmo as your car with the little green/red element that registers restriction, when the filter needs cleaning, the device trips to red. Clean the filter, push the reset button on the end and watch for it to turn red again. Excessive black smoke is a good indication that your filter is really stopped up bad and needs cleaning.
   / Kioti Air Filter #9
Randy, I sure hope your are cleaning the filter more than every 100 hours. Tractors arent like cars that you replace the filter everytime you change oil. This is a daily thing to do in dusty conditions.
   / Kioti Air Filter
I was told, if you have an air compressor, you should blow the filter from the inside out. Blowing from the outside just embeds the particles deeper in the filter.
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
1999 MATE END DUMP TRAILER (A52472)
1999 MATE END DUMP...
New Long Forks (A53002)
New Long Forks...
