kioti 3054
   / kioti 3054 #1
Tango
Does anyone know how to pull the injectors on a 1998 3054. The injector has two barbs on the middle of the injectors (fuel return lines?) Is there a special socket that goes over the injector or does the top of the injector come off first (or in stages). I don't think it was designed to come off using an open end. Thanks The tractor still won't start from previous post. Thanks Skip:confused2:
   / kioti 3054 #2
After the removal of the injector lines, the fuel return manifold (can be) is removed from the injectors and you can then access the injector(s) for removal
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2003 HEIL KILL TRAILER (A52472)
2003 HEIL KILL...
Wright Sentar (A50120)
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
