Kioti 2007 Hydraulic problem CK20S PLEASE HELP
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #1
wattsinwest
somers,ny
Kioti ck20s
Hi gentlemen,
Need some major help here, average home owner. just bought used unit and working it hard.
All started when my backhoe encountered a broken hose and I temp-repaired it.
The unit started to get weak pressure and move slow, I disconnected the backhoe and tried the front loader. It was slow acting also.
I then tried to operate the steering, that also started to fail.
I drained the fluids and changed filters, thinking maybe that is the issue?
Not to mention that I changed the oil filter ,fuel filter, air filter, lubed the unit. Thinking that I will be golden.
So the big test on Friday the 13th?? I started the unit and let it warm up, tried my front loader ( Nothing ) 3 point hitch ( Nothing ) steering ( Nothing )
I'm concerned I destroyed the Hydraulic pump, If so. Is it worth fixing. Please help some one..
Best regards,
Tractorless..
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #2
hey what happened????
You had some replies I came back after suppah and all I see is the OP post?????
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #3
IDK:confused3:
guess i posted in 2 forums, parts and hydraulics.
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #5
WHEW!
thanks for letting me off the hook....
thought I was losing it and would have to admit to the wife she was right all along! :D
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
50ft Fuel Line (A51573)
50ft Fuel Line...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
