King Kutter Wheel Arm drawing/measurements?
   / King Kutter Wheel Arm drawing/measurements? #1
jmngray
Massey Ferguson 1648 w/ CB20 and Loader
I have bent the crap out of all my wheel arms on my early King Kutter 6' finish mower. It's impossible for me to get the miter angles correct to make new ones. Doesn't anyone have straight ones they can measure or a CAD file so I can just cut new ones out? Mine are the earliest version which doesn't have the extra 1/2" piece welded to the top of the arm. This is the part I'm trying to build new. Tail Wheel Arm Fits 5', 6' & 7' King Kutter | Agri Supply
   / King Kutter Wheel Arm drawing/measurements? #2
Do you have the KK actual p/n out of the manual of the parts diagram? Looking the p/n up on the web may find answers to the measurements.
I have a KK brush mower with the wheel straight out the center back.
Knowing there are already 2 holes, it must bolt on somewhere. Thus you do have that spacing defined.
The angles matter or the wheel won't stay plumb. Its really the angle where it bolts and the angle where the bearing shaft is welded that I'm hunting for. I measured all four and they are all different because they have all been bent so much. I can just built them and then drill the holes at plumb, but then I may screw up the height adjustment by inches. I was just hoping for a simple drawing of one so I could CNC or miter the correct angles.
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Freeland 100 gal Water Trough (A50515)
Freeland 100 gal...
2012 Killbros 110 Grain Cart (A50514)
2012 Killbros 110...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
