Rear Blade King Kutter vs Land Pride rear blade
   / King Kutter vs Land Pride rear blade #1
plaindave
White Lake, MI
Kubota B7800
Anyone have comments on a King Kutter rear blade vs. a Land Pride? After two winters of plowing snow with my FEL and box blade I figured I could break down and get a blade to make the job easier.
Priced them out and the KK blade is about $150 less than a Land Pride. Normally I'd buy the Land Pride just to give the business to my dealer, but this is kind of a lot when you are talking about $200 for the KK and $350 for the Land Pride.
Given the intended use I was thinking about going on the cheap here.
   / King Kutter vs Land Pride rear blade #2
I own one of each, A 72" landpride & an 84" kingkutter.
Spent the money on the landpride & got it so it angles side to side.
Check them both out.
I found the LP to be a better and stronger blade.
Also check out the curveature or bend of the middle of the blade. The LP has more curve? and the KK is more flat. I dont no how else to put it.
I dont even use the king kutter blade. it was like $200.
But if you want to use is for dirtwork the LP is the way to go.
I think the curve make a difference in the cutting in dirt and also rolling of a material.
I would take the Landpride.
zipp
   / King Kutter vs Land Pride rear blade #3
I'd recently posted on here asking about rear blades because I'd been using the same thing as you to clear snow, and it just doesn't work. Just when I'd figured that KK was junk, I found that they make a HD series rear blade that is a beast. However, it cost well over $1000.00. Guess what, Land Pride makes a HD blade the same size and just about the exact same weight, and, it also cost well over $1000.00.
My only point is that I don't think you can say Land Pride is necessarily better than KK, because they both make so many different grades of rear blades. After perhaps over researching it, I ended up with a Land Pride RB84, which is a "medium" duty 7' blade that angles and tilts. The only KK blades in stock around here were the $200 KK blades. Those blades are for very light duty. If you have a really small tractor, they will work for you. Otherwise, even with a mid sized CUT, if you catch something solid with the blade while clearing snow, well, there went your $200.00 down the drain. Both companies make a good rear blade. It just depends on what your use will be and what blade is locally available for you. I found that the weight of the blade was a fairly consistant way to measure it's relative strength.
   / King Kutter vs Land Pride rear blade #4
If you do very much with a blade, you are money ahead to get a good one. If you don't you will wish you had for years to come, or you will trade it in on a better one later. I know this from experience. /forums/images/graemlins/crazy.gif
   / King Kutter vs Land Pride rear blade #5
Jerry what makes a good blade, are there any makes in particular that stand out from the others?
   / King Kutter vs Land Pride rear blade #6
Mike,
When I go to look at a blade, I usually look for a name brand. If you look at their mid-horsepower blades you will normally see a pretty well designed blade. That is not saying that a lesser know brand can't be a good blade, but if you look at a well know top brand in that hp range you will have a good example of a durable well made blade. Several of the better know brands use the same exact blade for their 40-75 horse range. The Hardee that I have can be had in at least 3 other brand names.
   / King Kutter vs Land Pride rear blade #7
Here are the blades that I was speaking of. They are a few differences in the third arms attachments but are the same blade with that exception. The BH blade extends the tilt pin through the rear cover and has a few options add on to it.
   / King Kutter vs Land Pride rear blade #8
Look at Midwest. Much heavier and nicer than the KK I looked at, and comparable to the overall quality of the Landpride I looked at. Delivered, it was a little more than the KK, and a bit less than the Landpride.
What I liked best about the Midwest is that it has tilt, swivel, and offset, all without tools. The KK had no offset, and the Landpride required wrenches to offset. Midwest has 4 different paint colors available - green, grey (to match your Kubota), blue, red. PM me if you want the name & number of the Midwest factory salesman that I purchased mine from. Shipping should be even less than it was for me, as their plant is closer to you in Illinois.
Here's the Midwest website.
   / King Kutter vs Land Pride rear blade #9
You know, I've been going to the web site for Midwest for the last couple years, and it still is incomplete and under constrution. For a company that seems to be trying to have Internet sales, you would think they would spend a little more time developing their web page.
   / King Kutter vs Land Pride rear blade #10
DocHeb, funny you mentioned that about the Midwest site. I've noticed the same thing. I even called them since they are well within driving distance from me, but they didn't seem interested in selling me a rear blade. /forums/images/graemlins/confused.gif They really didn't even seem interested in talking wth me. Even though I'd heard that they made a decent blade, that was all I needed to scratch them off of my list.
2018 TOP HAT  GOOSENECK TRAILER (A45333)
2018 TOP HAT...
132937 (A44391)
132937 (A44391)
2022 Chevrolet Express 3500 Police Transport Van (A42742)
2022 Chevrolet...
2015 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A42742)
2015 Bobcat T590...
YANMAR VIO35-6A (A45333)
YANMAR VIO35-6A...
1993 48’X96”  STRAIGHT FLATBED (A45046)
1993 48’X96”...
