King Kutter vs Frontier brush hog
   / King Kutter vs Frontier brush hog #1
JMER817
Platinum Member
Grass Lake, Michigan
John Deere 4120
I know these are light duty but that is all I need. Looking at the King Kutter L-72-40-P6-FH for $1149 or the Frontier 2072 for $1250. Any thoughts one way or another? These are both shear pin but thinking about a slip clutch...worth the extra $? I see TSC has a slip clutch add on for $250.
   / King Kutter vs Frontier brush hog #2
I'd go with the rc2072 but order it with the factory slip clutch. They can come with either
Brett
   / King Kutter vs Frontier brush hog #3
I've had a 60" Frontier for about ten(?) years or so, I use it to mow about 5 acres of pasture and some rough area along the driveway. It has consumed a few good sized rocks along the way, enough to ding up the deck a bit. It is still holding up well, I did touch up the paint a couple of years ago to keep the rust under control. I found that I needed to drill some drain holes between the deck supports to keep water from pooling on top of it.
I would have to say that it was a good value for the price, I want to say it was about $850 new when I purchased it.
Brett
The only unit they have is the shear pin type. This is a unique model since it does not have the Frontier or (John Deere) name on it but it is identical. So unable to order.
Ended up finding a nice lightly used Bush Hog brand SQ720. Does anyone know where I can locate a PDF of the manual for this model? I've been on the Bush Hog site and it shows everything else but this model.
   / King Kutter vs Frontier brush hog #7
You really don't want a slip clutch if you can help it. If you are continuously whacking things that could rip your drive line apart then yes. However for most of us the occasional unsuspected "whack" is what we experience. Reason for my answer is 37 years of Farming 101 at Hard Knocks U. Most cutters sit out in the weather. The slip clutch has to slip to function. If frozen due to rust or bolts over tightened it can's slip. If bolts are not tightened enough it slips trying to cut normal foliage.
A shear bolt on the other hand, Grade 2 works best with a locking (nylon insert ok) nut, with a tad of slop at the coupling interface....they last longer for me if a little loose.....reason for the locking nut. Just carry a couple of spares with you in addition to a punch, small hammer (or suitable substitute) and a couple of wrenches to fit.
   / King Kutter vs Frontier brush hog #8
I have to agree with Texasmark. I was upset when I found out my rotary cutter had a pin instead of the clutch it was suppose to. I bought that LandPride rc1260 new & the dealer said it had a clutch. Never broke the OEM sheer pin though. Once I got my tiller & had to do the annual spring clutch maintenance I decided I liked the pin on my rotary better. 0 maintenance over 3 years vs. Half an hour every spring... might be different if you have gnarly mowing & break pins a lot.
   / King Kutter vs Frontier brush hog #9
Call Wells equipment located in litchfield Mi.They are a brush hog dealer and might be able to get a manual.
   / King Kutter vs Frontier brush hog #10
Try looking for a manual for the SQ600. It's the same cutter - just 5' instead of 6'.
I did try googling quickly, but did not find anything. I'm sure I downloaded mine from the internet. Perhaps a good search will reveal something. Good luck.
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
2003 Ford Thunderbird Coupe (A42744)
2003 Ford...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
2019 Chevrolet Tahoe SUV (A42744)
2019 Chevrolet...
2014 Ford Escape 4x4 SUV (A42744)
2014 Ford Escape...
2007 INTERNATIONAL TRANSTAR 8600 TANDEM AXLE DAY CAB (A43003)
2007 INTERNATIONAL...
