I've read several threads that say the King Kutter tiller is not Quick Hitch compatible. Well, I don't know if it's just mine, but everything lined up fine. Had to loosen the back bolt and slide the collar back a touch but that is all it took.
Mine BARELY won't fit on one of the lift arm pins with the CAT 3 bushings on. It seems to be mostly working without the bushings. It hangs from the top link & the lift pins are a bit off the lift arm hooks.
The design should be compatible, but my tiller has some sloppy welds or bad tolerances. They should make the ears for the pins 1/4" or 1/2" longer and remove the possibility of issues.
I have the 5' KK just like that but the space between the lower links and the actual tiller frame isn't that large. I can barley get the hooks on the lower links w/o the cat 3 spacers like you have. Now mine is about 10 to 12 years old so it may have changed?
I want to get a 6' unit and I stopped by TSC today at lunch, and all of the new Country Line units have a tag on them manufactured by Tarter made in the USA, the 5' one had a tag that said QH compatible but the 4' and 6' didn't but you can tell they are made exactly the same way and are QH compatible there must be a sticker either hidden or in the parts package they weren't completely assembled. I will be getting one of those 6' ers, I really like them there isn't closed in spaces on the top for water and dirt to accumulate in like on the KK models were.
Couldn't see your photo earlier (think photos were messed up on all of TBN for a bit)... But on yours there is at least a 1/2" gap or so between the QH hook & tiller frame. On one side of mine, it's barely 1/8" & -1/8" on the other. I really need to get some photos, but it will probably be a week or 2 before I have reason to hook it up again.
I really want to like the KK tiller, very good price & otherwise great reviews for an economy piece of equipment. It just drives me nuts that better build quality, or an extra 1/2" of clearance on the design & it would be just fine.
I know what you mean. I'm kinda OCD about stuff like that too. Makes ya wonder, if they can't locate the pins accurately, what else did they not quite get right??
