King Kutter or Land Pride?
   / King Kutter or Land Pride? #1
cphilip
Clemson SC
Kioti 2610HST, Toro Titan ZX 5400 w Kawaski, Bush Hog rotory, Farm KIng tiller, Land Pride Box blade, Tiger attachments forks, Land Pride Grooming mower, EA Wicked 55" Grapple, Superior 20' 7700# Equip Trailer
If you had it down to those two used ones and all things model wise are about equal which would you chose? Are they about equal in quality and parts availability?
These both would be the lighter duty entry level models.
I tend to sort of lean to the Land Pride for some reason I just cannot recall.
   / King Kutter or Land Pride? #3
I vote yes on the Land Pride I think its better made than king cutter:2cents:
Well... thats what I was thinking.
What might make it easier is that the KK is probably not equal in condition now. I went and visited it today. Needs new belt, tension spring broken. Both Lift pins bent up slightly, safety shroud missing from drive shaft. Repaint. Pins holding Wheel assembly's all replaced with bolts and nuts. Otherwise it is functional and blades are decent shape and could be put back into shape with a hundred and a half or so bucks. Cosmetics aside.
Ill be looking up close at the landpride Monday but I already know its in better cosmetic shape and has as all its correct parts. I think its going to be a two hundred $ more in the end but won't be a project.
   / King Kutter or Land Pride? #5
I find a lot of implements built by 3rd parties of various sorts, function identically with different approaches. On a particular unit you may think that the designer is skimping on this or that (to meet pricing requirements) only to learn that he/she worked around the function, replaced it with something better, or put the function elsewhere. Case in point are 3 pt tillers in particular and light duty 3 pt rotary mowers.
   / King Kutter or Land Pride? #6
My vote would be for Landpride.
   / King Kutter or Land Pride? #7
I bought Land Pride over King Kutter. Land Pride was more expensive but to me the difference in quality, parts availability, and service justified the expense. Land Pride had an alliance with Kubota and was bought by Kubota in 2016 so parts and service were readily available and should be for a long time. Around me King Kutter is sold by retailers such as Atwoods or Tractor Supply which don't stock parts or do service. King Kutter parts are available online from King Kutter.
A Kubota Company | Land Pride
In this area King Kutter is sold by Northern Tool. And a new 60" is selling for $1600. The new 60" Land Pride I see listed as low as $2000. So yes the price is higher for a land pride.
At this time it looks like Land Pride is ahead of King Kutter as far as the condition and price of used ones available.
I have one other land pride implement. A Box Blade. And it was a bit beefier than its competition when I was comparing in the same price range. Wasn't sure that would transfer into anything else. In this case its a bit more complicated by the fact I am also comparing used and whats available.
   / King Kutter or Land Pride? #9
Sounds like the condition of the kk makes the difference. You save $50 but have to put time into it. Is the $50 savings worth the time you would have into the repairs you need?
Exactly.
As it so far is turning out. At first I was trying to justify the difference. But since only I could access condition I couldn't ask you guys to help with that. But so far its made up a lot of difference. Plus... even if I did get it cheaper and did put that into it, it would never end up in the same condition. I couldn't turn a sows ear into a silk purse. But I could turn it into a sack. But why? And whats my time worth on top of that?
Anyway... Ill go see the land Pride tomorrow and go prepared to buy. Unless something in person is significantly different its the better deal anyway.
Ill post back after my trip with pictures. Or with reasons why I rejected it.
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
JOHN DEERE 7210R LOT NUMBER 268 (A53084)
JOHN DEERE 7210R...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
